power seat issue in my 66 riviera
Results 1 to 9 of 9
Like Tree8Likes
  • 1 Post By CADforce69
  • 1 Post By Jeff R
  • 3 Post By carnut
  • 3 Post By cadillac kevin
The Classic Cadillac Forum Discussion, power seat issue in my 66 riviera in Past Cadillac Vehicle Discussion; I know its not a caddy, but I figure the seat bases are identical, so I might as well ask ...
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    I know its not a caddy, but I figure the seat bases are identical, so I might as well ask here. My rivieras power seat does not work. I can hear the motor run (sounds strong too), but the seat does not move. the seat is 2" too far forward for me, and my legs hit the lower dash/ column/ kick panel/ door panel when exiting the car. the seat is simply too far forward. how do I go about fixing the mechanism so the seat can move?
    CADforce69 is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac Sedan de Ville 1969, Dodge 3700GT '73, Audi A3 1.8T
    Oct 2010
    Madrid (Spain)
    49
    1,634
    Re: power seat issue in my 66 riviera
    It seems to be jammed. Have you tried to help the mechanism with your hands, pushing the seat backwards? I would look under the seat with a torch for something preventing the movement. Maybe some WD-40 on the critical point could help.
    Maybe some of the cables got loose or unplugged. If you can not determine what´s the problem, you will have to remove the seat and check it carefully. GM had different kind of power seats that applied to all bodies described on the Body by Fisher FSM, so the 66 body Fisher manual of any GM car or some years later, could help you.
    77CDV likes this.
    Jeff R's Avatar
    Jeff R is offline Cadillac Owners Enthusiast
    Automobile(s): 1970 Coupe De Ville//Cessna 172
    May 2013
    St. Louis
    47
    542
    If it's anything like the 70 there is a motor that attaches to a transmission. The trans has solenoids that move gears inside the trans. Those drive speedo cables that run to the tracks.
    If this is what yours is like then the transmission is probably not engaging. You can take it apart and clean it but if you just want the seat to move for now then take the speedo cable off the trans and stick it in a drill. Only move it a bit and then go to the other side so that it doesn't get jammed up.
    Jeff
    77CDV likes this.
    Feb 2003
    california
    69
    6,666
    Raise the seat all the way up. Look for short cables going from the seat motor to the seat tracks. More than likely one is stripped or disconnected. Push the seat switch while looking and you will see the problem. Bench or bucket seats? I owned a 66 Riv GS back in the day. Black on black bucket seats with 10 inch Cragers on it. Dad owned a tan 64 then I bought a 65, then sold it, bought the 66. It sure did like gas stations! It would pull to the right as I passed a Chevron station!
    77CDV, CADforce69 and talismandave like this.
    Dec 2010
    St. Louis, MO
    6,395
    I cannot raise the seat up all the way. it does not work in any direction.
    its a bench seat car (sadly), but its pretty sweet. plum with plum interior.
    I'll make sure to take a look when I get a chance though.
    Oct 2010
    Madrid (Spain)
    49
    1,634
    ^Beautiful!! I hope you can fix it... Bench seat is more difficult to handle. Maybe if someone helps you... I wish I could
    Feb 2003
    california
    69
    6,666
    A bench seat is just longer cables! You have at least 2 motors, one for fore and aft, one for vertical. If you can at least get the 2 front seat track bolts out of the floor pan, you should be able to tilt the seat back for a better look. NICE CAR! I love the 66's and 67's. Love the design of the speedometer face.
    Jeff R's Avatar
    May 2013
    St. Louis
    47
    542
    My uncle had a 65. Man I loved that car.
    There may be 2 motors, maybe not. Our 70 Deville has just 1 motor with long speedo cables.
    orconn's Avatar
    orconn is offline Cadillac Owners 10000+ Posts
    Automobile(s): Cadillac 95 STS, 02 SLS
    Oct 2007
    Midlothian, VA
    73
    13,792
    Really like the plum on plum, Kevin! Excellent color for that car.
  12. Remove Advertisements
