1968 brake issue
Results 1 to 8 of 8
The Classic Cadillac Forum Discussion, 1968 brake issue in Past Cadillac Vehicle Discussion; My 68 deville has drum brakes and it's acting weird when I first begin to slow down. Most of the ...
    sams2100 is offline Cadillac Owners Fanatic
    Automobile(s): 1968 DeVille Conv, 1999 DeVille, 2003 Escalade
    Oct 2008
    125
    1968 brake issue
    My 68 deville has drum brakes and it's acting weird when I first begin to slow down. Most of the time when you first begin to slow down, the car will jerk left (assuming the left front wheel is breaking before the right), and sometimes it will give a slight jerk to the right. Rarely it will jerk back and forth a time or two while beginning to slow down.
    After that initial swing to the left or right, it slows down as normal. Any ideas what might be causing this?
    smelvis is offline Cadillac Owners Fanatic
    Automobile(s): 1970 deville convertible
    Apr 2012
    Cumberland, RI
    204
    Sounds to me like something within the drums or drums themselves. I would think a hydraulic issue would be more consistent. I've had some drums do some funny things. Sometimes it's just a disassemble and cleaning that takes care of it.
    If it were me. I'd start from scratch to isolate any issues. Bleed lines to eliminate that possibility. Visually inspect both sides for any broken springs, hold downs etc. I'd switch sides on the drums too and take it for a spin to see how it reacts. If the drums are slightly out of round it will do some grabbing and other funky things. Then go in for the full brake job.
    When's the last time you replaced shoes and hardware or had drums spun?
    Oct 2008
    125
    Re: 1968 brake issue
    I haven't had anything done to the brakes at all. Have owned the car since late last year and didn't drive too much this winter. How irritating are the drum brakes on these cars? Last drum brakes I worked on was an 85 toyota pickup and I swore after dealing with those brakes I would never do them again.
    cadzombie is offline Cadillac Owners Member
    Automobile(s): 1968 Cadillac Sedan DeVille
    Jan 2011
    Houston, Tx
    32
    27
    I had this problem when I got my sedan deville. It turned out the old brake hose had nearly swollen shut. If you go through all the things smelvis said. I only caugh this because it was nearly impossible to bleed one side.
    sawyer is offline Cadillac Owners Member
    Automobile(s): 1969 coupe deville
    Aug 2013
    42
    35
    See if the shoes are chamfered on the ends of the pad itself if they are not that can cause grabbing. Oem shoes are but often aftermarket aren't.
    70eldo's Avatar
    70eldo is offline Cadillac Owners Connoisseur
    Automobile(s): 1970 Eldorado.
    Sep 2005
    Dutchman in Germany
    42
    4,023
    What comes to my mind is you could've switched the brake pads. The pads set in one drum are a slightly longer one and a slightly shorter one. But they have a symmetrical shape, so it is easy to have both short ones on your right side and the long ones on your left side without really noticing it when installing, hence the pulling to left when you brake.
    I drove around like this (only in the rear though) for a while and I never noticed, until it surfaced doing a brake test (on the brake test bench for yearly inspection) and I took apart the brakes. I had those brakes replaced by a workshop that time, because I was away and needed it done for an event.
    superjeep is offline Cadillac Owners Fanatic
    Automobile(s): 68 sdv,63 sdv,64 fleetwood,60 fleetwood,66 fleetwood
    Jun 2013
    34
    107
    i had such bad luck with my drums. switched to front discs and it was the best thing I've done to the car so far
    70eldo's Avatar
    Sep 2005
    Dutchman in Germany
    42
    4,023
    I think opgi has the brake conversion set?
  11. Remove Advertisements
