Tranmission Fluid for 64 DeVille
Results 1 to 9 of 9
Like Tree2Likes
  • 2 Post By aussiejohn
The Classic Cadillac Forum Discussion, Tranmission Fluid for 64 DeVille in Past Cadillac Vehicle Discussion; Where do I locate the dipstick for the transmission fluid and what is acceptable fluid for a 64 DeVille ?...
    64caddy is offline Cadillac Owners Member
    Automobile(s): 1964 DeVille convertible
    Mar 2014
    1
    CaddyGas's Avatar
    CaddyGas is offline Cadillac Owners Fanatic
    Jun 2012
    454
    Re: Tranmission Fluid for 64 DeVille
    Passenger side by the manifold. Dex/Merc, I also use it as power steering fluid. If there ever is a leak it is not as harsh as power steering fluid all atf fluid is a detergent.
    aussiejohn's Avatar
    aussiejohn is offline Cadillac Owners Member
    Automobile(s): 1964 Convertible, 1974 Corvette coupe, 1974 Corvette Vert
    Jan 2014
    Highett, Victoria Australia
    80
    CaddyGas,
    I don't know that what you said is such a good idea. My 2010 Holden Cruze recommends using the same fluid in both the PS pump and auto trans, but cars of the sixties and seventies do not. While ATF will work in a PS pump, it is not designed for the old pumps and should not be used. I sell Borgeson steering boxes Down Under and they do not recommend the use of ATF in their boxes. I always use AC Delco PSF in the boxes I sell as well as those on my 1983 Holden Commodore and 1974 Corvette, which has a Borgeson integral PS box. I used to use ATF in my 1983 Commodore, which has a Saginaw pump, but it started to leak after a few years. Even a "Stop Leak" fluid I added didn't stop the leak, only slowed it a bit.
    A wiser man than me told me to use PSF, so I drained the ATF and refilled with PSF. After a month or so, the leak stopped and it hasn't leaked a drop since. And that pump is the original 1983 Saginaw pump, never been rebuilt or even pulled apart! The car has done about 400,000 km, one new engine, but original pump. Yes, ATF will work, but it will probably leak after a while. Use PSF as GM designed and you won't have any problems.
    Regards from Down Under.
    aussiejohn
    carnut and 77CDV like this.
  5. #4
    77CDV's Avatar
    77CDV is offline Cadillac Owners 10000+ Posts
    Automobile(s): 77 CDV, 06 DTS III, 69 FWB
    Mar 2006
    Newbury Park, CA
    45
    10,021
    Any ATF fluid that's compatible with Dextron will work just fine.
  6. #5
    CaddyGas's Avatar
    Jun 2012
    454
    Thanks for the tap on the shoulder aussiejohn.
  7. #6
    aussiejohn's Avatar
    Jan 2014
    80
    Quote Originally Posted by 77CDV View Post
    Any AT fluid that's compatible with Dexron will work just fine.
    That's right, just don't put it in your power steering pump.
    aussiejohn
  8. #7
    70eldo's Avatar
    70eldo is offline Cadillac Owners Connoisseur
    Automobile(s): 1970 Eldorado.
    Sep 2005
    Dutchman in Germany
    41
    4,023
    Use DEXTRON III if you can get it. DEXTRON IV has additives that slowly eat the seals in your brake system (you'll notice the black 'clouds' in the master brake cilinder).
  9. #8
    77CDV's Avatar
    Mar 2006
    Newbury Park, CA
    45
    10,021
    Quote Originally Posted by 70eldo View Post
    How would trans fluid get in the brake system?
  10. #9
    70eldo's Avatar
    Sep 2005
    Dutchman in Germany
    41
    4,023
    Oops sorry, disregard! I mixed up the facts! Only applicable to brake system.
  11. Remove Advertisements
