transmission fluid question
Results 1 to 2 of 2
The Classic Cadillac Forum Discussion, transmission fluid question in Past Cadillac Vehicle Discussion; 66 deville.. it has a turbo hydramatic 400... Is royal purple max atf ok? It lists gm dexron fluids as ...
    rksm is offline Cadillac Owners Member
    Automobile(s): 66 coupe Deville
    Jan 2014
    Brampton, Ontario
    29
    It lists gm dexron fluids as compatible.
    Does that mean its also compatible with the A type atf, which is listed as the recomended fluid.
    77CDV's Avatar
    77CDV is offline Cadillac Owners 10000+ Posts
    Automobile(s): 77 CDV, 06 DTS III, 69 FWB
    Mar 2006
    Newbury Park, CA
    45
    10,022
    Re: transmission fluid question
    It it's compatible with Dextron, you should be good to go.
