Lower Door Panels for 76 Eldorado Conv.
Results 1 to 6 of 6
The Classic Cadillac Forum Discussion, Lower Door Panels for 76 Eldorado Conv. in Past Cadillac Vehicle Discussion; Does anyone have the lower door panels for both doors? Or are there any parts houses that carry these?...
    davidp1561 is offline Cadillac Owners Member
    Automobile(s): 1976 eldorado convertible
    Mar 2013
    50
    Jaykeane is offline Cadillac Owners Member
    Automobile(s): 73 LD Ragtop
    Sep 2012
    40
    Re: Lower Door Panels for 76 Eldorado Conv.
    Check this stuff.
    http://www.rustrepair.com/DOOR-BOTTOMS-OUTER-LIP.HTM
    they're 58" long and have been bent along one edge, the idea is to cut the repair area, and fit these in as a patch, and use a hammer and dolly to finish the bend to conform to the door frame.
    I purchased one of these for my Eldorado, but for use in another area (trunklid) they're 20 gauge steel, and cheap.. available from your local bodyshop supply shop.
    Mar 2013
    50
    Thank you for that info but I should have been more clear....I need the inner lower door panels for both doors as the armrest is cracked and peeling
    77CDV's Avatar
    77CDV is offline Cadillac Owners 10000+ Posts
    Automobile(s): 77 CDV, 06 DTS III, 69 FWB
    Mar 2006
    Newbury Park, CA
    45
    10,022
    I believe the inner door panels are a one-piece affair. Just have them reskinned.
    Mar 2013
    50
    you are correct sir. I will look at doing that thank you!
    emsautollc is offline Cadillac Owners Member
    Automobile(s): '59 conv,'76 Eldo bicentenial,'58 coupe
    Sep 2012
    38
    They are available from OPGI.com., and various other suppliers. I'm about to order a pair for my bicentennial eldo. Gary.
  9. Remove Advertisements
