Does a 1962 Series 62 AC use gas?
Results 1 to 6 of 6
Like Tree5Likes
  • 2 Post By CADforce69
  • 3 Post By aussiejohn
The Classic Cadillac Forum Discussion, Does a 1962 Series 62 AC use gas? in Past Cadillac Vehicle Discussion; Hello I have inherited a beautiful 1962 Series 62 from my father and am shipping it to my home in ...
    grahammoles is offline Cadillac Owners Member
    Jan 2014
    1
    Hello I have inherited a beautiful 1962 Series 62 from my father and am shipping it to my home in Australia. The importers request that the ac be de-gased for transit but I am unsure if the ac system uses gas? I am not that familier with the car and its not in my presence so any help would be great!! Thanks in advance
    CADforce69 is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac Sedan de Ville 1969, Dodge 3700GT '73, Audi A3 1.8T
    Oct 2010
    Madrid (Spain)
    50
    1,634
    Re: Does a 1962 Series 62 AC use gas?
    Check if your car has the A/C option. If not, you don´t have to do anything.
    If so, you will have to empty the gas in the car´s A/C system. Any mechanic can do it in 10 minutes. In 1962 these cars (as most A/C equipped ones) used R-12 gas in their A/C system. If the car keeps now this kind of gas, it would be a pity losing it, because it´s very difficult finding it nowadays (It´s illegal in most countries). If you recharge it with R-134 (the gas commonly used today), it won´t work the same without adaptations.
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,689
    Not "GAS" like gasoline but refrigerant gas! Yes it should have R12 in it now. If its required by the shipper, then do it. If its only a suggestion, then say no. R12 is outlawed in many countries so ask around locally if R12 is available where you are at.
    Oct 2010
    Madrid (Spain)
    50
    1,634
    ...And if de-gasing is compulsory, don´t forget to unplug the compressor clutch wire to avoid it works with no gas, what would damage compressor seriously!
    DouglasJRizzo is offline Cadillac Owners Enthusiast
    Automobile(s): 1975 hearse, 1976 hearse
    Nov 2010
    Franklin Lakes, NJ
    53
    865
    The refrigerant is frequently referred to as "gas" as said elsewhere in this thread.
    The '62 uses R12 refrigerant. You can use R134 with some minor adjustments to the system. I did it to my two hearses, no problems.
    Definitely have the system discharged before shipping and unplug the compressor.
    aussiejohn's Avatar
    aussiejohn is offline Cadillac Owners Member
    Automobile(s): 1964 Convertible, 1974 Corvette coupe, 1974 Corvette Vert
    Jan 2014
    Highett, Victoria Australia
    80
    Graham Moles,
    Yes, the Australian Government specifically bans the import of Freon or R12 refrigerant gas. However, you need to have the car de-gassed by a licensed refrigerant technician and have him sign a document to state that the gas has been removed from the car's system. Make sure that this document is easy for the Customs and AQIS inspectors in Australia to find when it arrives here. Also make copies of it and have a spare one in the glove box and have one mailed to you in case the others are misplaced. There are no problems with regassing with R134 in Australia, but a few parts will have to be changed. The AC system will work just fine if it's all done by a qualified AC technician here.
    Regards from Down Under.
    aussiejohn
  9. Remove Advertisements
