Front passenger side window issue-1971 Coupe Deville
Results 1 to 3 of 3
Like Tree3Likes
  • 2 Post By imabadczech
  • 1 Post By 1970CadillacCalais
The Classic Cadillac Forum Discussion, Front passenger side window issue-1971 Coupe Deville in Past Cadillac Vehicle Discussion; Hello again guys! My passengers side front window will go down with both switches and also up but only if ...
    imabadczech's Avatar
    imabadczech is offline Cadillac Owners Fanatic
    Automobile(s): 1996 Sedan Deville
    Feb 2013
    Marietta, GA
    49
    105
    Hello again guys!
    My passengers side front window will go down with both switches and also up but only if the window doesn't go all the way down. I always have the window about a half inch from all the way down but a friend wanted to hang his arm out the window and so he put it down all the way. I removed door panel, and could tell someone had been in the door before as there was some tape holding that inner plastic back on the door. I reached in as far as i could and grabbed bottom of window and just wiggled and pulled gently and eventually window was all the way up. Then my dumb ass put it all the way down again but nothing going up. I had to wiggle a bit harder then she went up again. Apparently the window motor is good and both switches are good. Any suggestions on this one?
    As always, I appreciate all your help.
    Feb 2013
    Marietta, GA
    49
    105
    Re: Front passenger side window issue-1971 Coupe Deville
    OK, figured it out. Took door panel off again and my roommate found the wires going to motor were all taped up. One of the wires had come out of the plug back in the 70's and someone just taped it back together. We repaired the plug and it works as new now.
    70eldo and talismandave like this.
    1970CadillacCalais's Avatar
    1970CadillacCalais is offline Cadillac Owners Member
    Automobile(s): 1970 Cadillac Calais
    Sep 2011
    Jacksonville, Fla
    69
    Good deal.
    imabadczech likes this.
