Carburetor Question
Results 1 to 10 of 10
Like Tree7Likes
  • 2 Post By CaddyGas
  • 1 Post By 77CDV
  • 1 Post By Submariner409
  • 2 Post By D Yaros
  • 1 Post By CADforce69
The Classic Cadillac Forum Discussion, Carburetor Question in Past Cadillac Vehicle Discussion; What's up everyone. I was wonder what carburator are y'all running on the older caddys? I've got a 1953 deville ...
    Westacles is offline Cadillac Owners Member
    Nov 2013
    3
    Carburetor Question
    What's up everyone. I was wonder what carburator are y'all running on the older caddys? I've got a 1953 deville with the stock 331. I can't seem to find a carb with the same size square bore as the stock carb I took out. Are y'all swapping intake manifolds as well? Any help would be appreciated. Thanks.
    CaddyGas's Avatar
    CaddyGas is offline Cadillac Owners Fanatic
    Jun 2012
    454
    Re: Cadburator Question
    1956 had the 365 motor with a carter carb. When you change carbs sometimes you need to change manifolds, make sure if you do you have hood clearance. Keeping it orig or going aftermarket is a matter of preference. If the car is all matching I would keep it original and get it rebuilt.
    Well......Obviously a 1953, see what you did brain. Scratch the first part, the later I stand by.
    70eldo and 77CDV like this.
    77CDV's Avatar
    77CDV is offline Cadillac Owners 10000+ Posts
    Automobile(s): 77 CDV, 06 DTS III, 69 FWB
    Mar 2006
    Newbury Park, CA
    45
    10,021
    Just rebuild your orig carb. Best course imo.
    70eldo likes this.
    70eldo's Avatar
    70eldo is offline Cadillac Owners Connoisseur
    Automobile(s): 1970 Eldorado.
    Sep 2005
    Dutchman in Germany
    41
    4,023
    I have to admit I was hesitant to rebuilding my carb by myself, but it wasn't that hard after all. I am happy I did it. I have to concur that rebuilding the carb is indeed the best option. You can find rebuild kits online like here <http://www.oreillyauto.com/site/c/se...&make=Cadillac>
    Nov 2013
    3
    Well my problem is that my choke spring is worn out on the original carburator and can not seem to find one that will work. Every choke spring I find works the opposite direction that I need. I might just have to put manual choke on it but I would like to keep it all original.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,877
    Talk to these guys - they have done several large Quadrajets for my boat engines. Nice work, not expensive. Long Island
    http://www.allcarbs.com/
    70eldo likes this.
    DouglasJRizzo is offline Cadillac Owners Enthusiast
    Automobile(s): 1975 hearse, 1976 hearse
    Nov 2010
    Franklin Lakes, NJ
    53
    865
    Re: Carburetor Question
    Generally, on old gals like the '53, keeping as much original as possible is preferred.
    But... sometimes an aftermarket carb may make a better driver.
    I'm usually leary of "Over-carbing" - where someone decides that if 390 CFM is good, 1500 must be better.
    D Yaros's Avatar
    D Yaros is offline Cadillac Owners Fanatic
    Automobile(s): 1955 CDV, 1992 Allante, 1962 Olds 88 Conv
    Nov 2009
    Milwaukee
    177
    There is no reason any number of places will not rebuild your carb, or you can do it yourself.
    Here is source for doing either - http://www.daytonaparts.com
    Here is info on DIY - http://GrayLady.WebNG.com/carbrebuild.htm
    70eldo and DouglasJRizzo like this.
    CADforce69 is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac Sedan de Ville 1969, Dodge 3700GT '73, Audi A3 1.8T
    Oct 2010
    Madrid (Spain)
    49
    1,634
    Quote Originally Posted by Westacles View Post
    Is Your carb´s spring a spiral type? My other car has a Carter 4300S BBD with a thermal choke that burned up so I could adapt an electric choke for a Holley (works the same but the heat source is electric instead of exhaust heat). The cap was the same diameter but the spiral spring worked the opposite direction so I just turned it to the opposite position (left to right) and it worked right first time.
    talismandave likes this.
    D Yaros's Avatar
    Nov 2009
    Milwaukee
    177
    I would think the choke spring would be able to be found/purchased. Have you tried Daytona Parts Co.?
    Also you state the spring "works the opposite direction." If you flip the spring over then in what direction does it work?
  13. Remove Advertisements
