1973 deville heater ...need help please..
Results 1 to 9 of 9
Like Tree6Likes
  • 1 Post By 70eldo
  • 4 Post By smelvis
  • 1 Post By Warspite
The Classic Cadillac Forum Discussion, 1973 deville heater ...need help please.. in Past Cadillac Vehicle Discussion; i tried turning it on no fan no heat...checked fuse its good and all wires look good hooked up to ...
    ponee is offline Cadillac Owners Member
    Automobile(s): deville
    Nov 2013
    16
    i tried turning it on no fan no heat...checked fuse its good and all wires look good hooked up to heater..
    77CDV's Avatar
    77CDV is offline Cadillac Owners 10000+ Posts
    Automobile(s): 77 CDV, 06 DTS III, 69 FWB
    Mar 2006
    Newbury Park, CA
    45
    10,021
    Re: 1973 deville heater ...need help please..
    Does the car have Automatic Climate Control? Does the blower operate in any switch position, or is it completely dead? If the blower runs in DEF, suspect the blower motor relay located on the relay cluster under the dash over the driver's side foot well. Once the blower motor is working, you can rotate the thermostate to maximum heat and it should roast you out of the car. If not, check for a blocked heater core.
    70eldo's Avatar
    70eldo is offline Cadillac Owners Connoisseur
    Automobile(s): 1970 Eldorado.
    Sep 2005
    Dutchman in Germany
    42
    4,023
    I don't know for 1973, but my 1970 has this vacuum switch for the blower motor. It is located on the back of the blower motor in the RH side of the engine back against the fire wall. It has 4 vacuum lines attached to it. This switch loses the ability to hold vacuum or it just gets too stiff to operate correctly. I have to aid mine and I put a piece of cloth behind the switch to close the switch. This way the blower motor is always running unless I remove that piece of cloth.
    I will send it to cadillactim.com next season to have it remanufactured.
    77CDV likes this.
    Warspite's Avatar
    Warspite is offline Cadillac Owners Fanatic
    Automobile(s): 1962 coupe (selling), 1995 Seville SLS, 1966 Sedan DeVille
    May 2010
    Atlanta, GA
    57
    244
    Quote Originally Posted by 70eldo View Post
    My '66 was obviously jury-rigged. I found a (broken) toggle switch which operates the blower motor. The climate control selector was stiff as a board. White lithium grease spray helped loosen it up a bit, which does now allow air to be directed. When I take the dash apart to replace the gauge cluster, it's an assembly that I'll either have to repair or replace.
    Jeff R's Avatar
    Jeff R is offline Cadillac Owners Enthusiast
    Automobile(s): 1970 Coupe De Ville//Cessna 172
    May 2013
    St. Louis
    47
    542
    I don't think my 70 Deville has that vacuum switch but it appears the eldorado does. However I think they both have the water temp switch. It does not turn the heat on until the water is warm so you don't have cold air blowing on your feet. Maybe that sensor has gone bad. Does it work in Defrost?
    smelvis is offline Cadillac Owners Fanatic
    Automobile(s): 1970 deville convertible
    Apr 2012
    Cumberland, RI
    204
    The deville does not have a vac switch connected to the blower.
    I've been going through my hvac system for months the blower has always worked because it spins even if the switch is off to purge the system.
    The blower speed is regulated at the control panel and through the power servo. It seems for my system all problems live at the power servo. I've taken it apart and cleaned it and gotten improved performance but not perfect. I suspect my transducer as well.
    Bottom line it take a long methodical approach to DIY these systems but it can be done. I'd start with testing the relay. And work your way from there.
    Btw cadillac Tim is great. Reasonable prices and a wealth of knowledge.
    Another thing- if you are just looking for heat once you get the blower moving. You can connect the vac feed to the top of the servo to the hot water switch and you will have heat only. That's how Daisy is rigged right now until I get the rest of the bugs out.
    70eldo, 77CDV, Warspite and 1 others like this.
    Warspite's Avatar
    May 2010
    Atlanta, GA
    57
    244
    Did Cadillactim change his URL? I was looking for his web site, but got his hosting provider's page instead. Hard to find good subassemblies for '65-'66 on ebay or Craigslist.
    70eldo's Avatar
    Sep 2005
    Dutchman in Germany
    42
    4,023
    Quote Originally Posted by Warspite View Post
    Seems to work alright
    http://cadillactim.com/page4.html
    Warspite's Avatar
    May 2010
    Atlanta, GA
    57
    244
    Many Thanks! I left off the "page4.html" and when added, I got to the site. I'll be on this one a lot, since not all posters on ebay or Craigslist remove the parts with care!
    70eldo likes this.
  12. Remove Advertisements
