Compression test engine - cadillac deville 63
Results 1 to 6 of 6
The Classic Cadillac Forum Discussion, Compression test engine - cadillac deville 63 in Past Cadillac Vehicle Discussion; Hi, Sorry for my easy language. Does anybody know about how many PSI should be on compression test for very ...
    Dzida is offline Cadillac Owners Member
    Oct 2013
    36
    15
    Hi,
    Does anybody know about how many PSI should be on compression test for very good condition engine Cadillac Deville 64' 6.4L 6392CC 390Cu?
    What value is very good, when good, when is bad, etc.
    Thank You for all answer.
    Feb 2003
    california
    69
    6,663
    Re: Compression test engine - cadillac deville 63
    As long as all cylinders are above 100 and within 10% of each other, they're OK. When they are 20% or below each other, then there's a problem internally. Best to do a dry test first on a warm engine then a wet test after that. A "wet" test is squirting a small amount of oil into each cylinder before doing the compression test. If the wet test improves the reading then you probably have weak, worn piston rings. All plugs removed, throttle fully opened is the proper procedure. If the dry test is OK, then a wet test might not be necessary!
    Oct 2013
    36
    15
    Thank You very much for response.
    So only more than 100 PSI mean that copression is good? Cadillac has big engine and I thought that maybe compression should be also higher than for example "regular" smaller engine.
    Feb 2003
    california
    69
    6,663
    The engine size does not matter, the compression rating does however. My statement of "over 100" is a general guide. Your concern is do all of them read about the same within 10%?
    Jaykeane is offline Cadillac Owners Member
    Automobile(s): 73 LD Ragtop
    Sep 2012
    40
    You'll also want to hold the throttle to the floor during the test, best to wire the throttle open so you're not pumping raw fuel into the intake via the accelerator pump. Above poster is spot on.. it's not a number thing.. it's a percentage thing..
    if you had say.. 84,80,87,84,88,40,86 and 82.. your issue would be the 40..
    Every gauge is different, none are NASA calibrated.. like the Light-Dark knob on the toaster on your kitchen counter..
    Jeff R's Avatar
    Jeff R is offline Cadillac Owners Enthusiast
    Automobile(s): 1970 Coupe De Ville//Cessna 172
    May 2013
    St. Louis
    47
    542
    If you have one that is low, blow some shop air in the cylinder and see where it is coming from. If you hear it blowing out the carb then intake valve. Out the tail pipe then exhaust valve. You'll have to find top dead center but it is worth a check. Sometimes a piece of carbon,etc will keep a valve from closing and running it a bit will clear it out.
  9. Remove Advertisements
