68 deville disc brake conversion
Results 1 to 5 of 5
The Classic Cadillac Forum Discussion, 68 deville disc brake conversion in Past Cadillac Vehicle Discussion; i have a 68 deville with drums all around, a friend of mine has a rotted 68 fleetwood with disc ...
    superjeep is offline Cadillac Owners Fanatic
    Automobile(s): 68 sdv,63 sdv,64 fleetwood,60 fleetwood,66 fleetwood
    Jun 2013
    34
    107
    i have a 68 deville with drums all around, a friend of mine has a rotted 68 fleetwood with disc brakes. im going to swap it over. ive read the spindles are the same and i can use my drum ones. i have seen a few different stories that the wheels are different and the booster is different. im taking the master off the doner car but my car has a new booster. i didnt know if the boosters needed to be changed too. i also have aftermarket 15 inch wire wheels on my car now. will those work with the disc set up? thanks
    Jun 2013
    34
    107
    Re: 68 deville disc brake conversion
    anyone? bueller?
    77CDV's Avatar
    77CDV is offline Cadillac Owners 10000+ Posts
    Automobile(s): 77 CDV, 06 DTS III, 69 FWB
    Mar 2006
    Newbury Park, CA
    45
    10,022
    I emailed this thread to GaryS. He knows all things 68 Cadillac and should be checking in soon.
    Garys's Avatar
    Garys is offline Cadillac Owners Fanatic
    Automobile(s): 1968 CDV / 1970 FWB /1979 FWB / 1995 Eldo
    Aug 2007
    San Diego
    228
    Quote Originally Posted by 77CDV View Post
    Thanks for the vote of confidence Craig!
    Your booster should work, but I would still grab the booster, along with the master cylinder. You will need the proportioning valve off the donor car. The rear wheel cylinders on the disc brake cars are a different diameter. If you don't want to change those over, you may be able to compensate with installing an adjustable proportioning valve, instead of the factory one off the donor. Pretty sure your aftermarket rims will work.
    Jun 2013
    34
    107
    Ok great!! Thank you so much. Ill see how these wheel cyls are. If they look crusty ill just get two new ones for a disc car. I was hoping i wasnt going to have to mess with the booster because mine is brand new,and this car is rotted in a barn with water soaked floor,maggot filled dead rodents, and the matching smell to that visual.....dont want to lay on the floor haha
  8. Remove Advertisements
