1940 gas tank
Results 1 to 3 of 3
The Classic Cadillac Forum Discussion, 1940 gas tank in Past Cadillac Vehicle Discussion; Hi everybody. I have a 1940 caddy coup series 62 modified .Q dos anyone know how many gals the original ...
    sherbercars is offline Cadillac Owners Member
    Automobile(s): 1940 cadillac coup series 62 modified
    Sep 2013
    1940 gas tank
    Hi everybody. I have a 1940 caddy coup series 62 modified .Q dos anyone know how many gals the original gas tank holds.? also can I use the original gas tank sender with newer gauge with 12 volt. BL
    Feb 2003
    california
    69
    6,627
    Re: 1940 gas tank
    My 1937 Olds had an 18 gal. tank, if that helps. The original 6 volt sender and dash gauge worked fine on 12 volts. Aftermarket gauges have different resistance values so the 1940 sender matching that resistance is a crap shoot at best. You need to verify the tank sender resistance, then find out what the dash gauge requires.
    Sep 2013
    Re: 1940 gas tank
    Quote Originally Posted by carnut View Post
    THanks for your reply and advice . BL
