77 eldorado vinyl to smooth questions
Results 1 to 3 of 3
The Classic Cadillac Forum Discussion, 77 eldorado vinyl to smooth questions in Past Cadillac Vehicle Discussion; Good day everyone. It must be that time of the year I am looking at turning the 77 eldorado into ...
    MrCads is offline Cadillac Owners Member
    Automobile(s): Eldorado
    May 2011
    7
    I am looking at turning the 77 eldorado into a slick top. The information on the topic seems to be very limited. I am looking for any piece of information on how this could be accomplished.
    Thank you
    CaddyGas's Avatar
    CaddyGas is offline Cadillac Owners Fanatic
    Jun 2012
    454
    Re: 77 eldorado vinyl to smooth questions
    Removing the vinyl top by scraping with a blade, if the glue is bad you can sand or use laquer thinner. Then there's body work no different then the rest of the car. Then of course prime and paint.
    May 2011
    7
    Quote Originally Posted by CaddyGas View Post
    Actually Kleen Strip, or whatever it is called works best for the foam and the paint. The problem is the trim around the rear window and the small side windows. I would like to keep it slick, and I need some window gaskets, seals of some sorts.
