Late '70's Cadillac Low Beam/ High Beam Question...
Results 1 to 13 of 13
The Classic Cadillac Forum Discussion, Late '70's Cadillac Low Beam/ High Beam Question... in Past Cadillac Vehicle Discussion; Hey everyone, I just can't recall the 'normal' operation from so long ago, so I put this out there. With ...
    Driver-8's Avatar
    Driver-8 is offline Cadillac Owners Member
    Automobile(s): 1979 Seville, 1999 Jeep GC Ltd
    Jun 2013
    Midwest USA
    52
    46
    Hey everyone,
    With the 1975-1979 quad rectangular sealed beam low/high config...
    ...is it normal for the low beams to dim down by about 50% when you manually turn on the high beams/brights?
    My high beam switch is the type still mounted on the left floor, but the result shouldn't matter if that style or column stalk switch.
    Thanks much. Mark~
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    44
    1,845
    Re: Late '70's Cadillac Low Beam/ High Beam Question...
    I'll check mine tonight.
    It could be you are increasing the voltage needs so much with the high beams that there is less juice going to the lows?
    I don't know why it would happen by design.
    Driver-8's Avatar
    Jun 2013
    Midwest USA
    52
    46
    Thanks for checking on it, let me know what you find with your '79. I do have the the optional high output generator/alternator. It has correct and steady output, even under load.
    Possibly a short in the switch... so i went on ebay and purchased a new floor mount dimmer switch and will install that when it arrives and see what happens afterwards. Certainly can't hurt to change it after 35yrs anyway.
    Mark~
    Feb 2003
    california
    69
    6,627
    The low beam bulb has 2 filaments. low beam and hi beam. The hi beams bulbs have one filament. Once the hi beams are selected the low beam bulbs should get brighter. Why don't you unplug the inboard hi beams and see if both filaments illuminate on the low beams when you engage hi beams. Could be 2 burnt out hi beam filaments in your outboard bulbs.
    Driver-8's Avatar
    Jun 2013
    Midwest USA
    52
    46
    Quote Originally Posted by carnut View Post
    Hey carnut thanks for the info. I will check out this out and report back.
    BTW... did you get to read the last detailed update on my old '1979 Seville help' thread? If not, you can check it out, but Bruce Roe tested & rebuilt my ECM with his custom designed MAP sensor, he also tweaked it using his bench test emulator. I then soldered in his under-dash external fuel pump relay bypass mod last weekend to protect the new ECU. Finally, to address the issue you were helping me with on the car, I found a like new fast idle switch on ebay and installed that as well. The car runs like new. There were big problems with the 35yo failing MAP sensor and my fast idle heater switch was not functioning properly. Even when it's warm out like now, the car still idles better & smoother on cold start than ever before, (A tad bit high right off, but kicks down quickly to a nice steady idle).
    Just thought you'd like to know and thanks again for all the help on resolving issues. Mark~
    talismandave's Avatar
    talismandave is offline Cadillac Owners Master
    Automobile(s): 1980 Eldorado, 1974 Talisman, 2004 Volvo C70,
    Mar 2012
    Madison WI
    57
    7,893
    Could the wires have been switched somehow? Like a replacement socket wired wrong?
    Neil Clarke's Avatar
    Neil Clarke is offline Cadillac Owners Member
    Automobile(s): 76 Sedan Deville
    Dec 2009
    Perth Western Australia
    48
    89
    Could also be a headlamp switch issue
    I have a similar problem on my 76 so bought one of these
    Its supposed to take the load off the switch
    Not yet fitted it to confirm
    http://www.ebay.com.au/itm/CERAMIC-H...f971036&_uhb=1
    Driver-8's Avatar
    Jun 2013
    Midwest USA
    52
    46
    Quote Originally Posted by Neil Clarke View Post
    Hey Neil,
    This looks good to me. I enjoy working on the car myself, and for the price this wouldn't hurt to give it a shot if I don't get anywhere after testing carnut's info on the dual filaments.
    I also purchased modern sealed beam assemblies, http://www.ebay.com/itm/UNIVERSAL-4X...d0746a&vxp=mtr
    but with projector lens inside and a removable superwhite H4 bulb (much brighter/whiter light), and this harness you found would make a nice new & clean install. I'm going to test the old original sealed beams per carnut, and then 2nd test with the old wires and new H4 bulbs... see if any diff, and go from there.
    Will post findings and pictures of anything out of ordinary.
    Thanks again everyone, I really appreciate everyone's help & input in this forum. Mark~
    bigm57ict's Avatar
    Aug 2011
    Wichita Kansas
    44
    1,845
    I tested the hi-beams on my '79 last night against the garage wall.
    The low beams did not get any dimmer when the high beams came on, but they did change. I think, like carnut said, a different fillament lit up.
    Driver-8's Avatar
    Jun 2013
    Midwest USA
    52
    46
    OK, so I went out to start testing some things and this time the dimmer switch is doing nothing at all, dead and the blue hi-beam crest indicator on the IP stays lit up all the time now. So... I pull back the carpeting and look what I found. I have done lots of work on this car myself, but never had reason to pull carpeting back before.
    This certainly cannot be original factory wiring. The car only had 1 other PO who, for over 30yrs. only had the car serviced by his local Cadillac dealer from brand new.
    This repair looks strange to me, I see no re-routing or mismatched wire colors (down here anyhow), why is it cut and re-connected right in line on all 3 wires? Did they remove something?
    Maybe carnut knows, but was something like what you see here (quick-splice connectors) used regularly for electrical repairs by Cadillac Dealer Service Technicians?
    I have never had any issues with electronic accessories, equipment or any shorting out problems. But, now that I stumbled upon this, I'm def gonna have to spend some time tracing out these wires and 4 headlamp wires to see if they all match up, (as you can see, they are all same color as dimmer switch wires), then discovering why this repair was done and working thru the replacement of the dimmer switch, etc 1 step at a time.
    FYI, I do own the original 1979 Service Manual and the electrical/vacuum circuit diagrams to refer to.
    Feb 2003
    california
    69
    6,627
    I'm thinking that maybe the fuse box is melted at either end of the fuse and it was wired to jump across that melted area to make better contact to the fuse? I've seen many floor mounted dimmer switches with melted connections at the dimmer itself after years of use. Given the history you mentioned, I'm thinking the technician was trying to do a quicker repair to save time and it must have worked up till now. Look at the dimmer itself for a damaged connector. And yes, we are now "friends"
    Dec 2009
    48
    89
    Just FYI on that kit I bought
    And I didn't get it from that guy but it looks identical to the one I did get
    Had this extra wiring info in the kit
    If you have changed your car to H4's without changing the pin configuration that might be the problem
    Driver-8's Avatar
    Jun 2013
    Midwest USA
    52
    46
    Hi Neil,
    Well, the problem existed (and still does) with the original design sealed beams. But... thanks for posting the sheets, this is excellent info for me once everything is corrected and setup with all H4's.
    For now, I have unplugged the brights and the H4 bulbs are working perfectly. I still intend on wire tracing and installing the new dimmer switch, then re-testing everything with all 4 bulbs active. From there, I'll see if I need that new harness. Mark~
  16. Remove Advertisements
