Vapor lock caddy-54 engine 331
Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By Caddy54
The Classic Cadillac Forum Discussion, Vapor lock caddy-54 engine 331 in Past Cadillac Vehicle Discussion; ...
    Caddy54 is offline Cadillac Owners Member
    Automobile(s): cadillac-54 serie-62 4 4door sedan
    Aug 2013
    Hi,
    I have a probleme with vapor lock in my Caddy-54. Some say I must put in an electic fuel pump but I´m not sure. I have talked to many old car owners and they have same probleme. Only cars with mecanic fuel pump. Many have installed elecric pump and then no probleme.
    What can I do?
    CADforce69 likes this.
    CaddyGas's Avatar
    CaddyGas is offline Cadillac Owners Fanatic
    Jun 2012
    454
    Re: Vapor lock caddy-54 engine 331
    Check if any lines run little too close to exhaust. You can insulate them that will help a little. Make sure their all in good condition. Some do ad a electric fuel pump. My 68 Impala gave me a problem with that, for some reasons caddy never did, at least not yet. Lines going to fuel pump I moved a little from exhaust, it help no vapor lock.
    Is that your car?.....Beautiful
    Aug 2013
    Quote Originally Posted by CaddyGas View Post
    Check if any lines run little too close to exhaust. You can insulate them that will help a little. Make sure their all in good condition. Some do ad a electric fuel pump. My 68 Impala gave me a problem with that, for some reasons caddy never did. Lines going to fuel pump I moved a little from exhaust, it help no vapor lock.
    Thanks. I have tried all that. It started this summer. They say it´s to much ethanol in fuel. So, maby best mont Electric pump.
    Yes it´s my car. More Pictures under Pictures.
    Thygo is offline Cadillac Owners Member
    Automobile(s): 1967 Sedan Deville
    Aug 2012
    62
    47
    Are you sure the fuel pick up in the tank is not clogged? I had that problem with my 67 and it appeared to be vapor lock but it was the sock filter on the fuel pick up in the tank. It is a cheap part but you probably need to drop tank.
    77CDV's Avatar
    77CDV is offline Cadillac Owners 10000+ Posts
    Automobile(s): 77 CDV, 06 DTS III, 69 FWB
    Mar 2006
    Newbury Park, CA
    45
    10,022
    Many owners of older cars, esp drivers that see a lot of sustained highway driving, have this happen. Installing a low pressure electric fuel pump cures the problem.
    70eldo's Avatar
    70eldo is offline Cadillac Owners Connoisseur
    Automobile(s): 1970 Eldorado.
    Sep 2005
    Dutchman in Germany
    42
    4,023
    Quote Originally Posted by Caddy54 View Post
    Hi,
    What can I do?
    Hey, you are from Sweden?
    Were you at Falkenberg this summer too?
  9. Remove Advertisements
