Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: Intermittent starting problem on 72 Eldorado
    Kevin Combs is offline Cadillac Owners Member
    Automobile(s): 72 Eldorado Convertible
    Aug 2013
    Northern CA
    9
    I having having trouble solving a starting issue on my 72 Eldorado. I have replaced the battery, starter, alternator and battery cables already. The car will start when jumped, however the battery tests OK (12.4 on the multimeter), and when running the alterator is shows it is charging around 14 on the multimeter. I can drive the car 10 miles and park and it will no longer start (most of the time). Sometimes the car will mysteriously start. One time I pushed the car to get to where I could jump the car and the door ajar buzzer sounded and it started again no problem. Any ideas on what to check next?
    70eldo's Avatar
    70eldo is offline Cadillac Owners Connoisseur
    Automobile(s): 1970 Eldorado.
    Sep 2005
    Dutchman in Germany
    42
    4,023
    Re: Intermittent starting problem on 72 Eldorado
    Maybe some lose cable(s)?
    FoxRodder's Avatar
    FoxRodder is offline Cadillac Owners Fanatic
    Automobile(s): 1968 Coupe Deville, 87 Mustang, 00 Mustang
    Aug 2006
    Orlando FL
    149
    When you say it doesn't start, what exactly do you mean? Do you mean that there is no electrical power in the car, Does the starter not spin the engine, does the engine spin over but not fire up?
  5. #4
    Aug 2013
    Northern CA
    9
    Fox Rodder, After driving the car when I go to restart I have no power period. The door ajar does not buzz, I get nothing when I turn the ignition. However headlights work. Test the battery and it shows 12.4. Hook up jumper cables and I get the buzzer and then the car starts without issue. no idea why the extra power helps when battery seems to be charged and alternator is charging battery too. Sometimes after opening the hood, etc the car will mysteriously start without hooking up jumper cables too.
  6. #5
    70eldo's Avatar
    Sep 2005
    Dutchman in Germany
    42
    4,023
    Check the cables to your starter. And the starter solenoid
  7. #6
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,688
    Loose connection at one end or the other. Cables at battery or wires, cable at starter solenoid. Also is there a ground strap from the engine to the frame or body? how clean, tight, is the ground cable from the battery to the car?
  8. #7
    FoxRodder's Avatar
    Aug 2006
    Orlando FL
    149
    Yea dirty/loose cables cause goofy intermittent problems. I've had dirty cables strike me many times on several cars. I've had power and door buzzer and when I turn ignition key I lost all power. Anytime you lose all power go right to the battery terminals and clean them. Some cars are more prone to these problems depending on the cables used. I had a guy one time that could not start his car, I hooked up my jumper cables to my car at the time that probably had an 800 cranking amp battery and his engine still would not fire up. I nearly gave him up for a tow truck but my last resort was a swiss army knife to clean the inside of his battery cables and bam it fired up.
  9. #8
    Aug 2013
    Northern CA
    9
    I have changed both positive and negative battery cables so they are all clean and should be tight. Battery is new too so connection is good. Starter is new too so I guess I have to climb back under and check all the the wires to the solenoid and starter next to make sure I didn't miss something when I changed the starter. Thanks for the ideas guys. I'll be back once I check all the wires/connections again.
  10. #9
    Feb 2003
    california
    69
    6,688
    If this a side post battery, I've seen the red plastic on a new positive cable prevent good contact at the battery even though it was tight. It was necc. to trim away the red rubber under the cable. Do you have a ground strap from engine to the frame? Where does the battery ground cable attach under hood?
  11. #10
    Aug 2013
    Northern CA
    9
    Carnut,
    It is a side post battery, but had same symptoms with old and new cable. Still worth checking though as I was concerned about the cables and thus replaced them.
    I have not looked for a ground strap from engine to frame. Will do that tomorrow night.
    The negative cable attaches to the frame just under the battery tray.
  12. #11
    Feb 2003
    california
    69
    6,688
    Most GM cars run a cable from a starter bolt to the frame. with the ground cable going to the frame from the battery there could be an issue with the starter circuit having a poor ground. Engines are mounted in rubber thru the mounts so a ground cable is important to ground the engine to the chassis.
  13. #12
    Aug 2013
    Northern CA
    9
    OK, ran through the wiring and everything seems to be in order. Battery is still charged at 12.45. Starter checks in at 12.28 or so. The Negative cable is firmly attached to the frame. There is a ground from one of the bolts holding the starter assembly to the frame. A flat woven wire that is about 1" wide that appears to be in good order. All wires are firmly attached to the starter solenoid.
    I have no power for lights, ignition, etc.
    Jump the car and I get enough power for lights, etc and can start the car without problem.
    Am I likely getting resistance between the starter solenoid and the ignition? Any ideas where to go next? Ways to troubleshoot my problem?
    Or should I go with a new wiring harness?
  14. #13
    Feb 2003
    california
    69
    6,688
    Jump starting only provides another battery so hi resistance would not be cured by jump starting. You are positive the side post cables are making a clean metal to metal contact at the battery? Jump starting simply by passes the battery in the car.
  15. #14
    Aug 2013
    Northern CA
    9
    I have good voltage to the starter solenoid so I believe the connections are all good. I checked them all this morning again for good measure.
  16. #15
    Feb 2003
    california
    69
    6,688
    Have someone hold the key in the start position while you bang the starter with a hammer. If it starts, I would suspect an open connection in the solenoid or starter windings. I would also remove the ground strap at the starter and shine up the cable end as well as shine up the frame where it attaches.
  • You may not post replies
