fuel pump replacement on 82 deville
Results 1 to 3 of 3
The Classic Cadillac Forum Discussion, fuel pump replacement on 82 deville in Past Cadillac Vehicle Discussion; Is there a trap door in the trunk to replace the fuel pump, or do I have to drop the ...
    Chadillac82 is offline Cadillac Owners Member
    Automobile(s): 82 Sedan Deville
    Jul 2013
    38
    4
    Is there a trap door in the trunk to replace the fuel pump, or do I have to drop the tank? My tank is full btw. If dropping the tank is the only way, does anyone have any tricks to share?
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,688
    Re: fuel pump replacement on 82 deville
    Siphon the fuel into another car. Drop tank to remove sending unit with pump attached. Make sure to replace the "sock" filter on the sender. I let my tank down from the back with the straps still attached at the front. The tank stayed under the car at an angle.
    Jul 2013
    38
    4
    Ok. Thanks.
