Window Motor 70 Deville
Results 1 to 6 of 6
The Classic Cadillac Forum Discussion, Window Motor 70 Deville in Past Cadillac Vehicle Discussion; I need to replace both my front window motors--70 Coupe Deville. Where is the best place to find them. I ...
    Jeff R's Avatar
    Jeff R is offline Cadillac Owners Enthusiast
    Automobile(s): 1970 Coupe De Ville//Cessna 172
    May 2013
    St. Louis
    47
    547
    Where is the best place to find them. I have found several that look the same but have different electrical connections. Does that matter if I just get one with an adaptor? Did they change the motors thru the years? Newer car motors that appear to have the same case are much less than a rebuilt one that says it is for my car. Any ideas?
    Jeff
    Garys's Avatar
    Garys is offline Cadillac Owners Fanatic
    Automobile(s): 1968 CDV / 1970 FWB /1979 FWB / 1995 Eldo
    Aug 2007
    San Diego
    228
    Re: Window Motor 70 Deville
    I know that the motors are the same at least through 1973. I took one out of a wrecked 1973 Olds 98 for my '68 CDV. I cut the connectors off both motors and soldered '68 connector on the '73 motor. It worked great! Your window motor just may need to be cleaned and lubricated. You might try it before you replace it.
    Jeff R's Avatar
    May 2013
    St. Louis
    47
    547
    I'll try the Olds route, thanks.
    The motors are bad--Water got in the doors and they are not salvagable.
    Garys's Avatar
    Aug 2007
    San Diego
    228
    Quote Originally Posted by Jeff R View Post
    I think any GM vehicle from that era will work.
    70eldo's Avatar
    70eldo is offline Cadillac Owners Connoisseur
    Automobile(s): 1970 Eldorado.
    Sep 2005
    Dutchman in Germany
    42
    4,023
    check rockauto or opgi
    cadillacbart is offline Cadillac Owners Fanatic
    Automobile(s): 1968 DeVille Convertible (current project)
    May 2005
    Thornton, CO
    157
    And the connectors with the adapters are fine.
  9. Remove Advertisements
