69 sdn roof moulding/trim
Results 1 to 9 of 9
Like Tree2Likes
  • 2 Post By 77CDV
  • 1 Post By 70eldo
The Classic Cadillac Forum Discussion, 69 sdn roof moulding/trim in Past Cadillac Vehicle Discussion; I finally got my car painted/body work done (even though its only a 2k maaco job) I opted to get ...
    SWEENDOG1969 is offline Cadillac Owners Member
    Automobile(s): 90k 1969 Cadillac Hardtop Sedan Deville
    May 2005
    seattle
    32
    95
    Question69 sdn roof moulding/trim
    I finally got my car painted/body work done (even though its only a 2k maaco job) I opted to get the spray on roof vs. the water/debris holding vinyl and plan on putting the trim/moulding that was around the perimeter of the top back on. My question is how would you do it? put the clips on the car and push the trim on to the trim or put the clips in the trim and try it that way?
    77CDV's Avatar
    77CDV is offline Cadillac Owners 10000+ Posts
    Automobile(s): 77 CDV, 06 DTS III, 69 FWB
    Mar 2006
    Newbury Park, CA
    45
    10,022
    Re: 69 sdn roof moulding/trim
    Clips on car, then trim onto clips. The other way lies madness.
    Cady70 and Cady70 like this.
    May 2005
    seattle
    32
    95
    1001164_4833222919657_1896235295_n.jpg999273_4833228119787_361605437_n.jpg999273_4833228119787_361605437_n.jpg
    I removed the roof trim all together...when I removed a couple pieces I bent them up alot so they couldnt straighten them.
    77CDV's Avatar
    Mar 2006
    Newbury Park, CA
    45
    10,022
    If it's damaged beyond repair, you'll have to source replacements from either a local j-yard (good luck) or a Cadillac-specific wrecking yard.
    May 2005
    seattle
    32
    95
    I said scrap the trim....so they ground off the studs,filled the holes and covered the whole roof. They wanted to go down the a pillar with that stuff and i said no way because it wouldnt look stock. I need to drop it off monday because they didnt prep good enough and the roof is bubbled up in a few spots along the edges.
    77CDV's Avatar
    Mar 2006
    Newbury Park, CA
    45
    10,022
    Why not just forego the trim and paint the car as though it never had a top?
    70eldo's Avatar
    70eldo is offline Cadillac Owners Connoisseur
    Automobile(s): 1970 Eldorado.
    Sep 2005
    Dutchman in Germany
    42
    4,023
    Nice car!
    I lost the vinyl top as well and went 2-tone.
    Attachment 116425
    SWEENDOG1969 likes this.
    May 2005
    seattle
    32
    95
    Quote Originally Posted by 77CDV View Post
    mainly because on the roof above the rear window they didnt "finish" the car very well because it was a vinyl top car and it had the cancer in the lower left area of the rear window under the top in the typical cadillac fashion. I used quik steel to fill the hole and they ground it down pretty dang smooth and prepped and primed and shot the bedliner stuff and it looks like a vinyl top without the hassle from pretty close up, and no more rust worries!
    I like that alot
    77CDV's Avatar
    Mar 2006
    Newbury Park, CA
    45
    10,022
    Don't bet on the no more rust worries bit. I've seen cars that never had a top still rust around the backlight. The lower channel just seems to be a magnet for water and debris.
  12. Remove Advertisements
