What is the best product to clean up and remove rust on real wire wheels?
Results 1 to 5 of 5
The Classic Cadillac Forum Discussion, What is the best product to clean up and remove rust on real wire wheels? in Past Cadillac Vehicle Discussion; The spokes are inserted extremely tight and there's no room for brushing, whats the best chemical to use on them ...
    TheChicagoan is offline Cadillac Owners Member
    Automobile(s): 1985 Eldorado
    Apr 2012
    28
    The spokes are inserted extremely tight and there's no room for brushing, whats the best chemical to use on them that won't ruin the chrome finish. Wouldn't Muratic acid work?
    Thanks,
    TheChicagoan
    CaddyGas's Avatar
    CaddyGas is offline Cadillac Owners Fanatic
    Jun 2012
    454
    Re: What is the best product to clean up and remove rust on real wire wheels?
    No. The acid will mess it up. Eagle One wire and chrome wheel cleaner, Simple Green are good. Sometimes I use the leaf blower or compressed air to blow out the water, good for tight spaces.
    Feb 2003
    california
    69
    6,627
    Naval Jelly from LOCKTITE
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,895
    I also used Naval Jelly on my old set of wires. Of course, areas where the chrome is damaged will not be restored, but they won't look rusty anymore. I applied, scrubbed with a toothbrush, and used a pressure washer. Wheels looked good.
    70eldo's Avatar
    70eldo is offline Cadillac Owners Connoisseur
    Automobile(s): 1970 Eldorado.
    Sep 2005
    Dutchman in Germany
    41
    4,023
    You may want to try dry ice blasting if the rust and dirt is more persisting?
  8. Remove Advertisements
