72 Deville help
Results 1 to 4 of 4
The Classic Cadillac Forum Discussion, 72 Deville help in Past Cadillac Vehicle Discussion; I have a 72 deville that I put a new edelbrock carb on because the Rochester had a lot of ...
    72DeVilleCT is offline Cadillac Owners Member
    Automobile(s): 72 Coupe D'Ville
    May 2013
    3
    72 Deville help
    I have a 72 deville that I put a new edelbrock carb on because the Rochester had a lot of problems and I got the edelbrock cheaply (but not used). I had to put two 1 inch spacers in to get clearance but everything is tight, the correct 4 bbl pattern and all. I hooked everything up, (the vacuum hoses were everywhere and only 1/2 hooked up before but it ran and drove) including a hose that is under the a/c compressor I didn't notice. The car runs great, throttle is much more responsive, idle is steadier, but now the car barely shifts from 1st. I have to rev it up way beyond the shift points, and then it shifts very hard.
    Where do I look to find the cause of the problem?
    77CDV's Avatar
    77CDV is offline Cadillac Owners 10000+ Posts
    Automobile(s): 77 CDV, 06 DTS III, 69 FWB
    Mar 2006
    Newbury Park, CA
    45
    10,021
    Re: 72 Deville help
    I believe the shift solenoid on this car is vacuum controlled. One of those disconnected hoses needs to get reconnected. That should solve your problem.
    May 2013
    3
    Re: 72 Deville help
    My actual problem is myself. I found the tyranny vacuum hose, it had fallen behind the engine. Guess what...when you do things right they work!
    All set, drove a good part of the day and got an unsolicited offer for the car at the gas station.
    Cadillac'n and life is good.
    77CDV's Avatar
    Mar 2006
    Newbury Park, CA
    45
    10,021
    Re: 72 Deville help
    Glad you got it sorted out!
  7. Remove Advertisements
