Update: 74 Fleetwood Talisman fires right up!
Results 1 to 3 of 3
The Classic Cadillac Forum Discussion, Update: 74 Fleetwood Talisman fires right up! in Past Cadillac Vehicle Discussion; After getting her home Friday, did a little washing/cleaning. Decided to see if the car is a runner or? Bought ...
    gold01ca is offline Cadillac Owners Member
    Automobile(s): 74 Fleetwood Talisman, 94 Geo Metro, 02 Ford F-350 Diesel
    Jul 2011
    Cranbrook BC Canada
    34
    Bought a new battery and a can of quick start.
    Checked oil (good/clean) and coolant (only needed a quart add).
    Quarter of a tank of 10 year old gas.
    2 blasts of quick start down the carb throat and on the second turn of the key, fired right up!!
    Burned a little blue for only a couple minutes and that cleared up.
    Quick trip around the block, blew out some black carbon smoke.
    Nice smooth idle, good throttle response, feels like full power!
    Initial observations:alternator bad,
    exhaust rotted at y pipe,
    power steering pump empty,
    idiot lights and some electrical not working.
    Is there a source for new exhaust system parts?
    Where is the fuse panel on the 74 Fleetwood?
    CaddyGas's Avatar
    CaddyGas is offline Cadillac Owners Fanatic
    Jun 2012
    454
    Re: Update: 74 Fleetwood Talisman fires right up!
    With 10 yr old gas, I would dump it first before I got it started. Glad it runs. Exhaust from a local shop. Fuse box is under dash.
    Feb 2003
    california
    69
    6,680
    Its common sense to drain and replace all fluids and that includes brake fluid! I would not trust anything rubber underhood especially fuel hoses. The new gasoline is very dry and will cause fuel hose leakage very quickly. to err on the safe side I'd replace all the rubber brake hoses and the 2 rear wheel brake cylinders. You must make sure the car will stop before you make it run better!!!
