Whats the better option, OEM Exaust Manifold or aftermarket headers? 85 Eldorado
Results 1 to 8 of 8
The Classic Cadillac Forum Discussion, Whats the better option, OEM Exaust Manifold or aftermarket headers? 85 Eldorado in Past Cadillac Vehicle Discussion; Manifold has a leak. We already removed the cat converter and put on a straight pipe. Now we need to ...
    TheChicagoan is offline Cadillac Owners Member
    Automobile(s): 1985 Eldorado
    Apr 2012
    28
    Manifold has a leak. We already removed the cat converter and put on a straight pipe. Now we need to know if sticking with original equipment is best for this design, or aftermarket headers would be better?
    Thanks in advance,
    TheChicagoan
    gold01ca is offline Cadillac Owners Member
    Automobile(s): 74 Fleetwood Talisman, 94 Geo Metro, 02 Ford F-350 Diesel
    Jul 2011
    Cranbrook BC Canada
    34
    Re: Whats the better option, OEM Exaust Manifold or aftermarket headers? 85 Eldorado
    I'm anxious to hear feedback on this as well.
    CaddyGas's Avatar
    CaddyGas is offline Cadillac Owners Fanatic
    Jun 2012
    454
    It depends what type of sound you want. Original manifold with a flowmaster, glasspack etc sounds good. Headers will just be louder.
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    Do they even make headers for the 4100?
    CaddyGas's Avatar
    Jun 2012
    454
    Not that I know of.
    Feb 2003
    california
    69
    6,627
    No headers available. If its the drivers side manifold, they get loose to the head over the years because of the heat stove shield around it. Remove the shield and check the bolts to the head, retorque as necc. My experience on that era of car is it might ping with any exhaust mod that would reduce exhaust back pressure. The EGR valve requires back pressure to open fully and at the correct time.
    Apr 2012
    28
    Quote Originally Posted by carnut View Post
    Dang, headers would have been cool. Nonetheless, my main concern right now is to repair whatever it is that's leaking carbon monoxide inside the car. I literally can only drive it 15 minutes before I start getting really sick. Could it be that the EGR valve not working be causing this? Or is the exhaust manifold the more likely perpetrator? I cannot see any cracks in the manifold itself, but my guess would be the manifold.
    Feb 2003
    california
    69
    6,627
    Without a cat converter, carbon monoxide increases! Can you hear the exh leak or just assume it leaks because of the getting sick? I would have preferred you checked the manifold bolts first before posting again. With a converter, untreated exhaust is present ahead of it. Without one, the whole exhaust can produce it.
  11. Remove Advertisements
