74 Fleetwood parking brake question.
Results 1 to 6 of 6
The Classic Cadillac Forum Discussion, 74 Fleetwood parking brake question. in Past Cadillac Vehicle Discussion; Am I correct, parking brake has no hand release? (car is 4 hours away or I'd go look ) P. ...
    gold01ca is offline Cadillac Owners Member
    Automobile(s): 74 Fleetwood Talisman, 94 Geo Metro, 02 Ford F-350 Diesel
    Jul 2011
    Cranbrook BC Canada
    34
    Am I correct, parking brake has no hand release? (car is 4 hours away or I'd go look)
    P. brake automatically releases when trans. is shifted into gear?
    Going on Friday to pick up car (inheritance/barn find) and getting my ducks in a row.
    Thanks!
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    44
    1,845
    Re: 74 Fleetwood parking brake question.
    If the car is equipped with the auto-release, you won't see the traditional pull handle on the lower dash.
    There should be a manual release, though. It is not as visible since it is only there in case the auto release is inoperative.
    Follow the pedal arm up from the foot pad. You should find a small lever to release the brake manually.
    Jul 2011
    Cranbrook BC Canada
    34
    Excellent, thanks bigm57.
    Just curious, is auto release a mechanical, electrical or electro-mechanical device?
    There's no battery in car right now.
    77CDV's Avatar
    77CDV is offline Cadillac Owners 10000+ Posts
    Automobile(s): 77 CDV, 06 DTS III, 69 FWB
    Mar 2006
    Newbury Park, CA
    45
    10,022
    Auto-release parking brake was a standard Cadillac feature in this era. It's a vacuum-operated system that releases the parking brake when the car is shifted out of park into any gear (except neutral), whether the car is running or not. The manual release lever that releases the brake if the auto-release feature doesn't won't release the pedal if the return spring or mechanical cable are frozen or broken.
    Congrats on your inheritance!
    Jul 2011
    Cranbrook BC Canada
    34
    Thanks 77CDV!
    I'm excited about getting the car home and seeing exactly what I'm dealing with here, Junk or Jewel.
    bigm57ict's Avatar
    Aug 2011
    Wichita Kansas
    44
    1,845
    Don't forget to post pictures when you do!
  9. Remove Advertisements
