'73 Eldorado Convertible Top Lift Motor Help Needed
Results 1 to 9 of 9
The Classic Cadillac Forum Discussion, '73 Eldorado Convertible Top Lift Motor Help Needed in Past Cadillac Vehicle Discussion; Hello all. I have a '73 Eldorado convertible, with what I believe is 52,000 original miles, and I'm having a ...
    1973_Eldorado's Avatar
    1973_Eldorado is offline Cadillac Owners Member
    Automobile(s): 1973 Eldorado convertible
    Feb 2013
    51
    27
    Hello all. I have a '73 Eldorado convertible, with what I believe is 52,000 original miles, and I'm having a problem with the folding top.
    It will fold down normally, but when I try to put it up, it will only raise about one quarter of the way. It just stops. If I hold the button, it doesn't click or snap or make any sound at all, the motor just slows to a stop and doesn't move anymore.
    At first I assumed a weak motor, but I also read somewhere that it's the relay that could be getting weak, and is not delivering the proper voltage to the motor. Would that by why it doesn't overload and the circuit breaker inside doesn't sound like it's doing anything? Or is the circuit breaker in the switch, not the relay?
    What is anyone's experience with replacing just the motor or just the relay? Or did you end up replacing both anyway?
    Thanks.
    mrbojangles041 is offline Cadillac Owners Member
    Automobile(s): Deville
    Aug 2010
    5
    Re: '73 Eldorado Convertible Top Lift Motor Help Needed
    Hmm... It could be the relay. Although I've always found that relays tends to fail open rather than supplying insufficient power. I have the same car and I've noticed that the top motor is pretty quiet while at the same time not all that strong. You might want to try greasing up all the hinges, joints and gears of the scissor lift if you haven't done so already. You could also try turning the headlights on, and have a friend watch to see if they dim a little more when the top stops moving. This would suggest that the motor is getting sufficient power and is struggling to move but can't. Also you could run a voltmeter across the wires to the lift motor to see if it's reading 12 volts or not.
    Hope that helps you troubleshoot the problem.
    smelvis is offline Cadillac Owners Fanatic
    Automobile(s): 1970 deville convertible
    Apr 2012
    Cumberland, RI
    204
    I researched some for my 70 Deville. Most of my research said the motors are pretty solid.
    The switches are notoriously bad and mine was. The switches in the 70 were not strong enough it seems. Mine was just about melted and the car came with a previously melted one in the glove box. It would go down but struggle on the way up. I jumped the motor to the battery at the switch to test the first time. There was definitely more power going up and after lots of lubing and having a buddy help the top up a few times she went up freely. I also replaced the switch with a 30a toggle.
    Jaykeane is offline Cadillac Owners Member
    Automobile(s): 73 LD Ragtop
    Sep 2012
    40
    On mine, I just had to cleaned the contacts on the relay.. Baisically, i unplugged them and re plugged them in a few times.. a squirt of contact cleaner followed by a blast of shop air for good measure and the top motor performs great..
    Relay is behind the rear seat back.. Lube the cables while you're messing around back there..
    Feb 2013
    51
    27
    Re: '73 Eldorado Convertible Top Lift Motor Help Needed --Solved
    Last week, I was finally able to get back to this problem and solve it. I was lucky. Able to get off easy and not spend any money. I called the people at Convertible Service (convertibleparts.com) and explained my symptoms to them. The man I talked to was very honest, and if I ever do need to buy parts, for sure they are who I will call.
    He explained to me how much the scissor-type top mechanism, motor and gear servos differed from the regular hydraulic system most other convertibles have, and how much more power it uses, and basically that the engine must be running to use it.
    I've had a '71 Cutlass convertible for many years, and putting the top up or down without the engine running is routine for me. But in regards to my Eldorado, the guy at CS told me that after lubricating everything, all the pivot points, to then put the top up, latch both sides, disconnect both cables at the servos (not at the motor), and use the palm of my hand to slap the bottoms of both top mechanism arms to make sure they were both fully spread out and settled in, in the same position as each other, then hook up the cables (with the top still up), release the latches and try it again, this time with the engine running.
    It worked, and that's all there was to it with my car.
    It was an easy job, and didn't even require removal of the back seat or trim panels to do it.
    Watching it work, it's clear to me the scissor mechanism is inferior to the older style. It was designed that way so the back seat could be a lot wider, because the side arms fold down behind the back seat, instead of along each side of it. In that sense, it works and does what it was designed for. But watching it work, it's flimsy looking, rickety, and I can see why broken parts are such a big problem for the scissor-style mechanism. It seems to have lots of play, lots of movement built in, so the mech arms can both pivot inward and back at the same time, where the old style mech basically just folds one way, straight back.
    But it does do what it's supposed to do. Keeping it well lubricated and checking on it often are probably the keys to making it last.
    If I were a dedicated one-car man like many of you, I would have bought a new motor, relay and cables just on general principles, but this is working well for now, and if I need to buy parts in the future, it won't be too difficult to install them.
    http://www.convertibleparts.com/scissor.htm
    talismandave's Avatar
    talismandave is offline Cadillac Owners Master
    Automobile(s): 1980 Eldorado, 1974 Talisman, 2004 Volvo C70,
    Mar 2012
    Madison WI
    57
    7,893
    Glad to you had such great luck with it, and got that gorgeous convertible performing as it should.
    This info will be of great help to other owners. As well as the heads up to an honest, helpful vendor who had nothing to gain from being so. Since it wasn't the motor perhaps the moderator could change the name of the thread to make it easier/more clear for future searchers to find it?
    Ike71 is offline Cadillac Owners Member
    Automobile(s): 1973 Eldorado Convertible
    Aug 2015
    Cincinnati, Ohio
    54
    1
    What do you mean by a blast of shop air? To clean out any dirt around it or into the cables themselves. I am having the same issue. The relay even shut down one time so I removed it from the front fuse box , let it cool down as it was hot as hell, replaced it and it began working again. Went down easily but then again got stuck a third of the way up. I greased everything, checked the cables to make sure they were tight and connected properly and I am still getting the same result. It works great going down so the motor works. Also one of the people in the blog said they replaced the relay with a 30 amp toggle? I also read that their is a relay on the motor itself? Is that true, and if it is I will change it also! The roof is in great shape, had t replaced 10 years ago and it is beautiful and all the mechanisms seem to be folding nicely but just not enough power. I even rev the engine and that helps a little. The car has 54,000 mile son it and recently repainted. Will never sell it but want to be able to put the roof up and down easily cause it limits when I can drive it! Thanks for any advise!
    kkkaiser is offline Cadillac Owners Member
    May 2016
    39
    I know this is an older thread but it follows some repairs i am having to address as i just got one of these,, same as yours,, mine is doing about the same thing,, needs help to pull the top up, with the button on and engine on. so when i was reading up on this, as it is on my list of things to try and fix,,, you stated that you did this,
    my question is were are the cables and connections on the servos and not on the motor,, are you talking about the top up and down motor or car motor? where is the servos located if you didnt have to pull all the back seats out..
    thanks
    Chadillac182's Avatar
    Chadillac182 is offline Cadillac Owners Member
    Automobile(s): 98 Concours, 01 STS, 02 deville, 06 DTS performance, 07 Esca
    Mar 2009
    Ontario, Canada
    35
    65
    Did you get your questions answered in this?
  12. Remove Advertisements
