Bench test power antenna?
Results 1 to 2 of 2
The Classic Cadillac Forum Discussion, Bench test power antenna? in Past Cadillac Vehicle Discussion; Hi all, Anyone know how I would go about bench testing my antenna? It has 2 wires, I believe blue ...
    wavedog's Avatar
    wavedog is offline Cadillac Owners Member
    Automobile(s): Cadillac 69 deville convertible
    Jul 2007
    Rhode Island
    40
    Hi all,
    Anyone know how I would go about bench testing my antenna? It has 2 wires, I believe blue and black? (have to confirm when I get home). Electrical is all disassembled in the car and wanted to test before I installed it.
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    44
    1,845
    Re: Bench test power antenna?
    I am only guessing, but I would try connecting the negative side of your power supply or battery to the case (ground). Energize Red or Black to make it go up or down.
    Now that I think about it, it depends on how it operates.
    Is there a switch on the dashboard to raise and lower it? If so, use the method above.
    If it raises up just by turning on the radio, then one wire carries power and the other gives the signal ("on" to raise, "off" to lower)
