door panels
Results 1 to 7 of 7
The Classic Cadillac Forum Discussion, door panels in Past Cadillac Vehicle Discussion; New member, got a 76 sedan deville. needs door panels repaired. I'm located in so cal orange co. Need a ...
    JIMPA is offline Cadillac Owners Member
    Automobile(s): 1976 sedan deville
    Apr 2013
    door panels
    New member, got a 76 sedan deville. needs door panels repaired. I'm located in so cal orange co. Need a guy who can match orig color and pattern. Thanks to all. JIM
    Apr 2013
    Re: door panels
    next Question, Info on best way to remove panels.
    carolinamic is offline Cadillac Owners Member
    Automobile(s): 1976 Cadillac Calais
    Nov 2012
    37
    6
    Re: door panels
    I still kind of new around her myself, but i think that the door panel is only held on by a few screws. 1 behind the door handle and a few along the split.
    cadillacbart is offline Cadillac Owners Fanatic
    Automobile(s): 1968 DeVille Convertible (current project)
    May 2005
    Thornton, CO
    157
    Probably some screws, and some clips around the perimeter of the panel. Also likely screws running through the armrests and door pulls into the door.
    See if you can find a shop manual for your year. You'll use it all the time.
    CaddyGas's Avatar
    CaddyGas is offline Cadillac Owners Fanatic
    Jun 2012
    454
    Re: door panels
    Yeah like some have said for screws around the perimeter, some even add some over the years. When they are all out, lift up on the panel to remove it, to get it out of the grooves on top. The door pulls come off with the door panel and are screwed on backwards.
    Corey468's Avatar
    Corey468 is offline Cadillac Owners Fanatic
    Automobile(s): 1976, 1994 Cadillac Fleetwoods, 1996 Lincoln Town Car
    Sep 2012
    Walnut, CA
    22
    204
    Re: door panels
    I couldn't ever find anything in the shop manual concerning door panel removal, but perhaps I missed it. In any event, I found this a while ago, http://1976eldorado.com/door-panel-removal/ . It's for an Eldorado, but I believe that the door panels are pretty similar to the RWD Cadillacs.
    FoxRodder's Avatar
    FoxRodder is offline Cadillac Owners Fanatic
    Automobile(s): 1968 Coupe Deville, 87 Mustang, 00 Mustang
    Aug 2006
    Orlando FL
    149
    Re: door panels
    There is a place I found that specializes in repairing dash pads. I think they work on door panels and other stuff too. My door panels are damaged as well. They cracked in the middle while otherwise they are not in bad shape except for the gaping holes where it cracked in half.
    http://www.justdashes.com/
  10. Remove Advertisements
