new to convertible...not to caddys
Results 1 to 6 of 6
The Classic Cadillac Forum Discussion, new to convertible...not to caddys in Past Cadillac Vehicle Discussion; My 69 deville conv. Motor works.... Well every other day. Is it getting hot? The fluid looks like fresh atf. ...
    disturbio's Avatar
    disturbio is offline Cadillac Owners Fanatic
    Automobile(s): 1969 DeVille convertible, 72 sdv - RIP
    Apr 2013
    az
    35
    182
    Questionnew to convertible...not to caddys
    My 69 deville conv. Motor works.... Well every other day. Is it getting hot? The fluid looks like fresh atf. Should I try to bleed it somehow? Thanks!
    Dirtywaterdiver's Avatar
    Dirtywaterdiver is offline Cadillac Owners Fanatic
    Automobile(s): 1968 Convertible
    Jul 2010
    Boston MASS
    268
    Re: new to convertible...not to caddys
    Start with top down!
    Get a spare motor reservoir drain plug.
    Top off motor with fluid till it just drips back out hole.
    get a 2" length of brake line about 7/32. A foot of nylon hose (Enough to have jar below pump), and a glass jar with lid.
    Fill the jar halfway with fluid. Poke a hole in the lid. Cut the tip off the spare plug at the goes-into end.
    Slide the small 2" brake line into the plug. Jam plug in the motor fill hole. Attach nylon hose to brake line and feed other end into hole in lid and down into fluid.
    Lift and drop top repeatedly (a lot). It should suck and spit fluid as needed and blow all the bubbles out.
    Allow pump to run 10 seconds more after full up and down to purge well.
    Do this with car running. better than running off battery.
    As you do it the top will become almost totally silent!
    Will work like a dream for years then.
    disturbio's Avatar
    Apr 2013
    az
    35
    182
    Thanks,
    I grabbed a Chilton but it has jack about tops.... I'm buying a opgi vinyl top to replace the tattered original top. I don't know what quality they are but I'm divin' in. Gotta get the thing bleed and see if it makes a difference.
    disturbio's Avatar
    Apr 2013
    az
    35
    182
    Where would one find a reservoir plug
    Jul 2010
    Boston MASS
    268
    disturbio's Avatar
    Apr 2013
    az
    35
    182
    Thanks... Love your 68 too
  9. Remove Advertisements
