69 deville interior paint
Results 1 to 6 of 6
The Classic Cadillac Forum Discussion, 69 deville interior paint in Past Cadillac Vehicle Discussion; I have a 69 deville and need to paint a map light cover...I got one for cheap and its greenish ...
    SWEENDOG1969 is offline Cadillac Owners Member
    Automobile(s): 90k 1969 Cadillac Hardtop Sedan Deville
    May 2005
    seattle
    32
    95
    I have a 69 deville and need to paint a map light cover...I got one for cheap and its greenish but not the dark green as my dash/interior.
    77CDV's Avatar
    77CDV is offline Cadillac Owners 10000+ Posts
    Automobile(s): 77 CDV, 06 DTS III, 69 FWB
    Mar 2006
    Newbury Park, CA
    45
    10,021
    Re: 69 deville interior paint
    They make paint specifically for plastic. Find as close a match as you can. I'd start with a hobby shop.
    1973_Eldorado's Avatar
    1973_Eldorado is offline Cadillac Owners Member
    Automobile(s): 1973 Eldorado convertible
    Feb 2013
    51
    27
    One additional option; find the discount auto paint stores closest to you, and start calling around. Some of them will custom mix a color if you supply a code, or they may be able to just use a sample. They will mix it and put it in an aerosol can for you. It's not crazy-expensive, I had it done about a year ago for less than $20.
    P.Katson is offline Cadillac Owners Member
    Automobile(s): 1966 Eldorado
    Oct 2007
    San Diego
    53
    You can use a paint for plastic aka "dye". SEM is a very good product and a auto paint supplier will have paint chips. However, for such a small piece that has little or no contact compared to a seat, I would make the correct color a priority and use spray paint over plastic dye if it is a better match.
    talismandave's Avatar
    talismandave is offline Cadillac Owners Master
    Automobile(s): 1980 Eldorado, 1974 Talisman, 2004 Volvo C70,
    Mar 2012
    Madison WI
    57
    7,893
    Krylon Fusion and Rustoleum Universal are both for plastic. Rustoleum also has a plastic primer that any of their paints will go over. Zinsser 123 is also a good primer for plastic.
    May 2005
    seattle
    32
    95
    I think I might have the mobile interior repair guys take a wack at it...also need them to look at a tear/wear spot where mice helped themselves to some seat cushion.
  9. Remove Advertisements
