New Member and question on 1967 OEM wheels
Results 1 to 10 of 10
Like Tree3Likes
  • 2 Post By V8der
  • 4 Post By Dingo
The Classic Cadillac Forum Discussion, New Member and question on 1967 OEM wheels in Past Cadillac Vehicle Discussion; Hello all, I posted this in the RWD Deville section but after looking around i thought it may be better ...
    V8der's Avatar
    V8der is offline Cadillac Owners Member
    Automobile(s): 1967 Cadillac Sedan De Ville
    Feb 2013
    40
    4
    Hello all,
    I posted this in the RWD Deville section but after looking around i thought it may be better suited here. My name is Eric and i'm new to the forum. I have a 67 Sedan De ville that I have owned for about 11 years. Car is incredible shape and is my pride and joy! I recently have wanted to take the wire wheels off and put a set of stock steel wheels back on it with some 3 inch whitewalls. I have done some searches but haven't found anywhere i can locate a brand new set. Would anyone happen the know the best place to get a set? I know 15x5 is a pretty common steel wheel for a lot of cars but i want to make sure and get a set that will fit my factory hubcaps. any help i would appreciate! Below is some pics of my car.
    CADforce69 and CADforce69 like this.
    Dingo is offline Cadillac Owners Member
    Automobile(s): 1967 Cadillac Fleetwood Series 75 Sedan
    Sep 2012
    Australia
    45
    18
    Re: New Member and question on 1967 OEM wheels
    Cool looking ride! I can't help you with the rims but with my limited photoshop skills I can roughly show you what it would look like with the stock wheels with a thin white wall...
    V8der's Avatar
    Feb 2013
    40
    4
    that looks awesome! Thanks!
    FoxRodder's Avatar
    FoxRodder is offline Cadillac Owners Fanatic
    Automobile(s): 1968 Coupe Deville, 87 Mustang, 00 Mustang
    Aug 2006
    Orlando FL
    149
    I'm pretty sure they are 15X7. I've got what I was told was the original ones from my 68 sitting in the garage and was trying to decide if I should use them or not. Car came with nearly identical wheels mounted but painted red with a chrome trim ring. Can't ,make up my mind if I should paint the other set black before I get new tires. I think yours looks great with the wires.
    Andrew224's Avatar
    Andrew224 is offline Cadillac Owners Fanatic
    Automobile(s): '41 67, '66 75, '02 Deville-L, DTS, DTS-L, XTS, '08 Escalade
    Apr 2012
    Plainfield, IL
    37
    132
    You won't find brand new stock wheels for your '67, if by chance you do, they'll be priced sky high. Gonna need to make a lot of calls to junk yards. They shouldn't be too hard to find. For good used ones, you're looking at about $75 / piece, maybe less.
    cadillacbart is offline Cadillac Owners Fanatic
    Automobile(s): 1968 DeVille Convertible (current project)
    May 2005
    Thornton, CO
    157
    Make sure you get stock steel wheels for a Cadillac. The way the stock hubcaps grip the rim is different than others.
    Also if you have disk brakes in front, you'll need different rims.
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,397
    Shouldn't rims from a rwd caddy up until 92 work? I know you can swap caddy hubcaps from different years on their steel rims.
    mgil is offline Cadillac Owners Member
    Automobile(s): 1968 cadillac deville convertible
    Aug 2012
    31
    I just found one on ebay they had the correct part , although a little pricey ,you might give them a try,@ allfactorywheels on ebay
    FoxRodder's Avatar
    Aug 2006
    Orlando FL
    149
    Just measured my 68 wheels and they are 7" outside lip to lip and inside where the tire actually seats I measured 6" so I'm assuming they are 15x6
    jock82 is offline Cadillac Owners Member
    Jul 2003
    sallisaw, oklahoma
    71
    35
    The 1967 is one of my all time favorite Cadillacs, I love the styling. I had a 1970 coupe de ville, but I really like the vertical headlights on the 67.
  13. Remove Advertisements
