Freshening up the 472 - Need Some Help
Results 1 to 5 of 5
The Classic Cadillac Forum Discussion, Freshening up the 472 - Need Some Help in Past Cadillac Vehicle Discussion; Hey Guys, this is my first post on this forum, looks like a great resource with lots of folks that ...
    CaddyNamedBVev is offline Cadillac Owners Member
    Automobile(s): 1970 DeVille Convertible
    Feb 2013
    32
    4
    Hey Guys, this is my first post on this forum, looks like a great resource with lots of folks that have some good Caddy knowledge.
    My Dad purchased a 1970 DeVille Convertible about a year ago, it's been a great car but she's got some pretty bad leaks around the oil pan gasket and the the water pump gasket. And the timing chain is pretty stretched and probably just on the edge of letting go, and timing her has been a nightmere so, we've decided to pull the motor and fix things up and clean everything.
    We pulled the 472 this past weekend and have now got it on a stand in the garage, good thing we pulled it because two of the freeze plugs were also just about to let go, they were both showing signs of leaking so we lightly tapped them with a screwdriver and it went right through! So we'll be replacing those too.
    My frist question for you guys is how do you pull the external balancer? It seems like we need a 4 point puller with a square pattern but we cannot seem to find the "right" puller at any of our local parts stores, is there a certain manufactorer anybody can recommend or do most guys make their own pullers? We need to remove the external ballancer to get to the timing chain but we're in need of some advice, can anybody help?
    Thanks,
    Nick
    FoxRodder's Avatar
    FoxRodder is offline Cadillac Owners Fanatic
    Automobile(s): 1968 Coupe Deville, 87 Mustang, 00 Mustang
    Aug 2006
    Orlando FL
    149
    Re: Freshening up the 472 - Need Some Help
    I don't have the answers but there is another forum called cadillac power that mainly deals with the 472 and 500 engines which should be chock full of stuff like that
    Dirtywaterdiver's Avatar
    Dirtywaterdiver is offline Cadillac Owners Fanatic
    Automobile(s): 1968 Convertible
    Jul 2010
    Boston MASS
    268
    Contact Marty at MTS, website 500cid
    Got everything you need.
    CaddyGas's Avatar
    CaddyGas is offline Cadillac Owners Fanatic
    Jun 2012
    454
    You are talking about the main crankshaft pulley right. There is a cork plug in the middle of the pulley that needs to taking out so the harmonic can be pressed on.
    Feb 2013
    32
    4
    Guys, thanks for the info here. Sorry it's been some time since I've been on here, I'll try 500cid, thanks for the recommendation.
  8. Remove Advertisements
