65 deville rear end leaky
Results 1 to 2 of 2
The Classic Cadillac Forum Discussion, 65 deville rear end leaky in Past Cadillac Vehicle Discussion; I knew i didnt want to mess with it in the first place!! but being winter and shes stored i ...
    livinproof is offline Cadillac Owners Member
    Automobile(s): 1965 coupe deville, 96 9c1 caprice, 04 tundra, 98 fordescort
    Jan 2013
    kalamazoo michigan
    38
    I knew i didnt want to mess with it in the first place!! but being winter and shes stored i figure why not.
    So i pulled the drive shaft (replaced the u joints and cv joints since i was there) and im wanting to replace the pinion seal and the pumpkin gasket. But now that i have everything broke loose it does not just slide apart... the front load portion.
    So im curious if guys just rtv the two halves or what? so it dosnt have to seperate?
    And after watching a couple utube vids i kind of screwed my self when i pulled the splined flange off the pinion because i didnt mark the relationship or count the revolvutions. So im unsure how to reset the pinon nut tension??
    Any advice appreciated
    02603sec's Avatar
    02603sec is offline Cadillac Owners Fanatic
    Automobile(s): STS 1SF Black V8 2006
    Sep 2008
    Bucks County PA
    57
    456
    Re: 65 deville rear end leaky
    get on ebay and find a helms factory service manual. It may help a little.
