NEED HELP! (electrical)
Results 1 to 4 of 4
The Classic Cadillac Forum Discussion, NEED HELP! (electrical) in Past Cadillac Vehicle Discussion; 66 deville...had all my lights working then running lights and brake lights quit found a wire i pinched on the ...
    SIK66CADDY is offline Cadillac Owners Member
    Automobile(s): 1966 cadillac deville
    Nov 2012
    32
    1
    66 deville...had all my lights working then running lights and brake lights quit found a wire i pinched on the back bumper fixed it but still no running lights and brake lights on theback any help would be awesome.
    DouglasJRizzo is offline Cadillac Owners Enthusiast
    Automobile(s): 1975 hearse, 1976 hearse
    Nov 2010
    Franklin Lakes, NJ
    53
    865
    Re: NEED HELP! (electrical)
    possibly the short caused a fuse to blow?
    SWEENDOG1969 is offline Cadillac Owners Member
    Automobile(s): 90k 1969 Cadillac Hardtop Sedan Deville
    May 2005
    seattle
    32
    95
    maybe fusable link? my 69 lost interior lights,windows,door locks,brake lights...after checking fuses and more fuses and jumping fuses still nothing. finally after searching around on the internet for a wiring schematic I figured out where the fusable link was and it was all melted up.
    mgil is offline Cadillac Owners Member
    Automobile(s): 1968 cadillac deville convertible
    Aug 2012
    31
    The 68 i just bought had electrical issues with the blinkers ,tailights , brake lights etc. the previous owner had jerry rigged a switch for the blinkers on the column, what a mess ! Anyway i bought a new switch for the blinkers and installed it , what a job fixing all the cobbed up wires and such. Well after it was installed we still had the same issue , after hours of trying this and that we finally found the problem. There was a loose ground on the front passenger blinker !! We tightened that up and bingo everything worked, amazing that one ground could cause all that trouble ! check all connections and make sure they are clean and tight !
  7. Remove Advertisements
