1957 coupe deville brakes
Results 1 to 5 of 5
The Classic Cadillac Forum Discussion, 1957 coupe deville brakes in Past Cadillac Vehicle Discussion; The 57 Cadillac Coupe Deville has a brake problem where at speeds over 50 miles an hour there is a ...
    jerrywagner is offline Cadillac Owners Member
    Automobile(s): 1957 Coupe DeVille
    Aug 2011
    3
    The 57 Cadillac Coupe Deville has a brake problem where at speeds over 50 miles an hour there is a terrible break shudder basically in the front end and we turned the drums replaced the brake shoes I adjusted everything according
    to the Cadillac factory manual front end aligned and balanced and nothing seems to make this shutter go away does anyone have any ideas
    CADforce69 is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac Sedan de Ville 1969, Dodge 3700GT '73, Audi A3 1.8T
    Oct 2010
    Madrid (Spain)
    49
    1,634
    Re: 1957 coupe deville brakes
    Did you check if tie rod ends or center link are worn / loose? Tires are old or were changed recently to be sure they are not warped?
    Aug 2011
    3
    Quote Originally Posted by CADforce69 View Post
    we think we have narrowed this down to a frame flexing issue, the car has a 1969 engine and the prior owner "trimmed" dome of the frame to make it fit and we are going to replace part of the frame from a donor car we have to see if that is the issue
    talismandave's Avatar
    talismandave is online now Cadillac Owners Master
    Automobile(s): 1980 Eldorado, 1974 Talisman, 2004 Volvo C70,
    Mar 2012
    Madison WI
    57
    7,893
    yikes...
    akaBC is offline Cadillac Owners Member
    Automobile(s): 57 conv 58 CdV 60 conv 67/69 Eldos 67 CdV 72 CdV MORE!
    Nov 2012
    Palm Springs CA/Mansfield OH
    47
    To quote Dave, "Yikes!" The 57/58 X-frames had a problem with the strength of the A-arms, anyway . . .. . . .The 58 model 62 Ht and my (former) 58 Coupe deVille had one break--one while crossing a street dip, the other while parking. In Van Nuys. Mebbe I should stay out of Van Nuys? Ooops--off-topic I go. . . .
    Also, did you replace all brake springs when baby needed two new pairs of shoes?
  8. Remove Advertisements
