58 cadillac dash bulb replacement
Results 1 to 11 of 11
The Classic Cadillac Forum Discussion, 58 cadillac dash bulb replacement in Past Cadillac Vehicle Discussion; I recently got a 58 series 62 and one turn signal indicator bulb and the instrument panel lights are burned ...
    58caddyman is offline Cadillac Owners Member
    Automobile(s): 58 series 62 2DHT
    Dec 2012
    32
    6
    I recently got a 58 series 62 and one turn signal indicator bulb and the instrument panel lights are burned out, I can get the instrument panel loose but I can't get it to pull
    out. Does anybody know how to replace the bulbs in the dash? Thanks.
    carnut is online now Cadillac Owners Master
    Feb 2003
    california
    69
    6,612
    Re: 58 cadillac dash bulb replacement
    Is the speedometer cable disconnected? If not, unscrew it from the transmission. That should give you the needed space.
    Dec 2012
    32
    6
    That makes sense, how does the column shift lever connect, do I have to do anything with that? Thanks for the answers.
  5. #4
    akaBC is offline Cadillac Owners Member
    Automobile(s): 57 conv 58 CdV 60 conv 67/69 Eldos 67 CdV 72 CdV MORE!
    Nov 2012
    Palm Springs CA/Mansfield OH
    47
    Are you anywhere near the San Fernando Valley? If so, I can put you in touch with a friend who can show you stuff. And things.
    BC
  6. #5
    Dec 2012
    32
    6
    unfortunately not, I'm in Montana.
  7. #6
    Nov 2012
    47
    Well, that's OK--it I won't hold it against you. . . .(just kiddn).
    My (pink-ish, actually "beige" according to the factory) "62" Cpe is in LA (The Valley), but if you ever need advice or photos to help you re-vitalize your unit, let me know. Did you get yer bulbs replaced? Taking off the speedo cable from the back should give you room to r&r, and while it's off, you can cable-lube it before re-install. Also, the bake-lite in the oil pressure sending switch on the top rear of the engine is NOTORIOUS for leaking over time. To replace it, you need the special socket. So, sock it to it!
    BC
  8. #7
    Dec 2012
    32
    6
    Sounds like we have the same car. I'm gonna try to get it out tomorrow. I think I'm going to have to do some cable work as the speedometer doesn't work, I'm guessing (hoping) bad cable. What do you lube it up with? Thanks for the help and advice, I'm looking forward to restoring the 'Ol girl, I'm sure I'll have to take you up on the advice or photos.
  9. #8
    Feb 2003
    california
    69
    6,612
    I've always used a very light coat of wheel bearing grease. You might find it easier to disconnect the cable housing at the transmission in order for the cluster to pull back. The inner cable comes out from the top once its disconnected from the cluster.
  10. #9
    Nov 2012
    47
    Well, if the cable has snapped, you may have to un-do both ends and remove it from either or both. There is actually a product called cable lube, but I suspect it is little more than a light lithium grease (from the planet Lythia, you know. . . .). Wheel bearing grease is a little too stiff (even more so than Wildroot hair cream!), not to say stiffening is a bad thing. . . .at times. . . . I'm going to try to get some photos posted if I'm allowed to. My friend Tim and I took the 58 on a tour/photoshoot, which included backgrounds like the Glendale Public Library, Topanga Canyon, the Santa Monica Pier, the Queen Mary, and the Griffith Observatory. Fun day, that.
    BC
  11. #10
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    44
    1,845
    Quote Originally Posted by akaBC View Post
    BC
    Of course, you plan to post some of these photos, right?
  12. #11
    Nov 2012
    47
    'Course! Gotta find 'em foist. . . . have a buncha others I think y'all might like, too.
  13. Remove Advertisements
