New Owner Red 1970 Deville Convertible - Page 6
Page 6 of 6 FirstFirst 123456
Results 76 to 78 of 78
Like Tree9Likes
The Classic Cadillac Forum Discussion, New Owner Red 1970 Deville Convertible in Past Cadillac Vehicle Discussion; I think the idling problem is fixed and it runs a bit smoother now. I replaced the vacuum advance canister ...
  1. #76
    klinebau is offline Cadillac Owners Member
    Automobile(s): 1970 Deville Convertible Red
    Jul 2012
    76
    Re: New Owner Red 1970 Deville Convertible
    I think the idling problem is fixed and it runs a bit smoother now. I replaced the vacuum advance canister and cleaned up the weights in the distributor, but I think the problem was a vacuum leak. The temperature sensor on the air cleaner was leaking. I didn't notice when setting the timing because I would typically pull this line and plug it. I will probably just leave that line plugged and not run heated air bypass valve.
    70eldo likes this.
  2. #77
    Jul 2012
    76
    Still not happy with the idle. It will idle at the right speed in drive (600), but is rough. When in park, it still has a rough idle but the exhaust will also randomly chuff every second or so (chuff... chuff, chuff, chuff.... chuff...). I've been working on it on and off for a couple of months now. The car runs fine everywhere else except at idle.
    So far I have
    - Adjusted the idle mixture about a dozen times with various combinations of lean/rich settings. The idle mixture screws do affect RPM and it will idle low so I don't think I have a major vacuum leak. No setting will give a smooth idle.
    - Confirmed no vacuum leaks. I previously replaced all vacuum lines but I have also disconnected and plugged all the vacuum lines to test that the problem remains. Using carb cleaner, I have sprayed around the engine bay (intake manifold, carb base, vacuum lines, brake booster, etc.) with no changes to idle quality.
    - Replaced distributor and most ignition components (points, condenser, rotor, cap). Previously, I noticed that the timing was off over 4 degrees at idle between cylinder 1 and 4 and is the main reason I replaced the dizzy.
    - I replaced the plugs and wires when I first purchased the car and they only have about 350 miles on them.
    - I replaced the carb with a rebuilt unit shortly after purchasing.
    Today I made some interesting observations. Using the dial back function on my timing light (90*), I looked at timing for cylinders 3, 8. The timing marks were jumping around wildly (10 degrees). The timing on #1 and #4 is rock steady at 8 BTDC. I pulled the #8 plug and it looked oil fouled (#3 looked fine). It didn't seem really bad compared to other pictures I saw online, but the insulator was black along with the electrode and ground. I cleaned up the plug and put it back in, but it didn't fix the idle.
    What should I do now? I should perform a compression test. I don't have one currently, but will get one. Would new plugs fix the problem? I haven't replaced the plugs since I bought the car and they could have fouled due to previous mis-adjustments (bad carb, vacuum leaks, etc.) I am guessing that the valve seals have deteriorated or are missing. What are the chances that this problem could be fixed with with new valve seals? What else should I consider?
  3. #78
    Jul 2012
    76
    Been thinking about this overnight. The #7 plug was also a bit fouled, but not as bad. That means both rear plugs are fouled. It seems most likely to be a valve guide seal problem. I am still going to check compression, but am likely going to replace valve guide seals. I think I can replace them without removing the heads.
