69 Eldorado Power Steering Pump
Results 1 to 7 of 7
The Classic Cadillac Forum Discussion, 69 Eldorado Power Steering Pump in Past Cadillac Vehicle Discussion; Hello fellow Cadillac lovers. This is Caddygas, new to this forum. I have a 1969 Eldorado I was wondering is ...
    CaddyGas's Avatar
    CaddyGas is offline Cadillac Owners Fanatic
    Jun 2012
    454
    I was wondering is removal of the power steering pump reservoir, and installation to the new pump pretty much straight forward, or are there any precautions, special tools etc.
    Thanks.
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,689
    Re: 69 Eldorado Power Steering Pump
    You will be dealing with O rings on the pump to the cannister. Just use steering fluid to pre lubricate them. No special tools other than a pulley puller to transfer the pulley to the new pump. Once together and on the car, have the front wheels off the ground, fill the cannister, then gently turn the wheels all the way both directions, engine running, then come back to center. Shut off engine and recheck the level. do not hold the wheels all the way left or right while doing this! This purges the air and eventually the noise will quit. Make sure your cannister is not bent from a prior owner prying on it to tighten the belt! If bent, the seal might not hold.
    CaddyGas's Avatar
    Jun 2012
    454
    That is what I figured, I just wanted to make sure. Thanks for the info, I can not get enough.
    CaddyGas's Avatar
    Jun 2012
    454
    Alright, I got the girl done. The pulley puller did not work, nothing for the pulley to screw into. Impact gun worked great, then a friend held the pulley as I took a rubber mallet and wacked the shaft so the pulley would slide off. Unfortunately the old reservoir was bent, got a new unit.
    smelvis is offline Cadillac Owners Fanatic
    Automobile(s): 1970 deville convertible
    Apr 2012
    Cumberland, RI
    204
    Hey Caddygas,
    I'm trying to rebuild my ps pump on my 70 convo. It looks like the modern pullers won't help. You mentioned something about an impact wrench. Does the nut in front of the pulley actually come off? If so how did you hold the shaft or pulley in place.
    I'm lost. The shop manual calls for a tool that doesn't seem to exist anymore. Any insight would be appreciated.
    CaddyGas's Avatar
    Jun 2012
    454
    Yes the nut in front of the pulley comes off. Have someone hold it while you take a impact gun too it. There is no way too use a puller. If needed when you take the nut off, smack the shaft with a rubber maker if the pulley does not slide off. Then just re install.
    Apr 2012
    Cumberland, RI
    204
    Thanks for the info!
    Didn't even need help. Held the pulley with one hand and the wrench did the rest. Had her apart in 30 mins.
  10. Remove Advertisements
