Results 1 to 3 of 3
Thread: 1973 eldo convetible heater core replacement
    jimi58 is offline Cadillac Owners Member
    Automobile(s): 1973 eldo 1993sts
    May 2012
    58
    3
    hi i could use any and all help here, heater core is leaking coolant into the int. of the car, i assume i need to replace the heater core? of all the eldos ive owned this my 9th, i never had a heater core problem, so it this a pain to do? i did on a 64 impala once and that was ez, so how bad on the caddy? again any help would be great!! thanks jim
    77CDV's Avatar
    77CDV is offline Cadillac Owners 10000+ Posts
    Automobile(s): 77 CDV, 06 DTS III, 69 FWB
    Mar 2006
    Newbury Park, CA
    45
    10,022
    Re: 1973 eldo convetible heater core replacement
    If I recall correctly, the core is behind the IP. I'd highly recommend getting a factory service manual to help you on your way. I don't think replacing the core is hard, but it will be time-consuming.
    72HearseGuy is offline Cadillac Owners Member
    Automobile(s): 1972 fleetwood hearse
    May 2012
    27
    35
    I replaced the core on my 72 fleetwood. Not difficult just took some time. Had to disconnect the in and out hoses, then there were four screws on the engine side of the fire wall that hold the housing. You have to remove the glove box and some dashboard to get it out.
  • You may not post replies
