76 Eldo Hubcap Question
Results 1 to 6 of 6
The Classic Cadillac Forum Discussion, 76 Eldo Hubcap Question in Past Cadillac Vehicle Discussion; Ok super newbie question. As the eldo is front wheel drive, are there limitations to what hupcaps to use? From ...
    Fanbladeus02 is offline Cadillac Owners Member
    Automobile(s): 1976 Cadillac Eldorado Convertible
    Mar 2012
    32
    6
    Ok super newbie question. As the eldo is front wheel drive, are there limitations to what hupcaps to use? From what I know about front wheel drive cars (and nothing of this vintage) the offset of the rim prevents certain caps being used.
    I'm not a big fan of the stock cap and plan on getting a set of wire spoke caps. I've come across a few from the late 70s/ early 80s that look cool but will they work?
    Also I see the dome that gets bolted to the rim and there is a lock nut and key? How do these work? Do you knock out the center to attach it?
    77CDV's Avatar
    77CDV is offline Cadillac Owners 10000+ Posts
    Automobile(s): 77 CDV, 06 DTS III, 69 FWB
    Mar 2006
    Newbury Park, CA
    45
    10,021
    Re: 76 Eldo Hubcap Question
    The wire discs will not work on these Eldos. If you want wires, you have to get true wires made for these Eldos. They are $$$$$$. There were also alloy rims available, but they are also $$$$$$$$.
    DouglasJRizzo is offline Cadillac Owners Enthusiast
    Automobile(s): 1975 hearse, 1976 hearse
    Nov 2010
    Franklin Lakes, NJ
    53
    865
    77CDV is correct.
    The reason for Eldorados having different wheel covers was that the wheels were offset differently to clear the much larger brakes/rotors/wheel hubs. Finding custom covers/wheels for these cars is expensive. They do exist, however.
    Mar 2012
    32
    6
    I must have gotten super lucky as I came across a set of wires that I believe will fit. Next time I'm over where I'm storing the car I'm going to clean them up and take pics --hopefully of them installed. Maybe you guys can tell me what it is that I have.
    They have a Cadillac emblem in the middle and have a high pitch with a separate wheel shield. These bolt right on with the rims and have chrome lugs. I put it on the spare rim and it seems to fit perfectly.
    So far looks like I got a score.
    Nov 2010
    Franklin Lakes, NJ
    53
    865
    Congrats! As I said these things do exist, but they're not that common. One thing that's been lost in the annals of time is that Eldorados, despite their size, were the "drivers car" of 70s Cad lineup. So things like larger brakes, stabilizer bars, larger tires, etc were part of what was included. Cadillac denied it, and I have no proof, but a few old timers have told me that Eldorado engines were higher output than the others. Again, the literature I have does not bear this out, but more than one old time mechanic has told me this. Maybe something we didn't know?
    bosshogg80 is offline Cadillac Owners Member
    May 2012
    5
    Any pics yet on your wheels you luck up on?
  9. Remove Advertisements
