1961 cadillac fuel problem
Results 1 to 7 of 7
The Classic Cadillac Forum Discussion, 1961 cadillac fuel problem in Past Cadillac Vehicle Discussion; anyone ever hear of this problem,new 390 motor,fuel tank and lines clean,new edelbrock carb with an extra inline filter.the car ...
    midnite kid is offline Cadillac Owners Member
    Automobile(s): 1961 fleetwood,1977 sedan deville
    Nov 2010
    8
    anyone ever hear of this problem,new 390 motor,fuel tank and lines clean,new edelbrock carb with an extra inline filter.the car when idiling will fill the bowl on the fuel pump but wont fill up the clear inline filter after the pump.after it idles a while,the bowl goes dry like its not pumping.i can feel the pump pumping when you lay your hand on it.is the rod between the cam and fuel pump wore out or is it sucking air.every line is newwas this a common problem
    daniel58 is offline Cadillac Owners Fanatic
    Automobile(s): 58 Coupe Deville, 77 Coupe deville, 90 Deville
    Sep 2009
    183
    Re: 1961 cadillac fuel problem
    I worked on a Chevy a while back that had the rod you mention wear out, so they do wear out. Problem is where are you going to get a new one. If it is the same as Chevrolet, you can get one at any speed shop. My experience is that parts stores such as NAPA will not have it.
    intragration's Avatar
    intragration is offline Cadillac Owners Fanatic
    Automobile(s): 1970 Coupe DeVille, 2002 Eldorado Collector Series
    Feb 2008
    Northlake, IL
    198
    I don't know if there's an in-tank filter at the end of the pickup tube like on some other cars, but if there is, it's possible for this filter to get wedged on the end of the pickup and block it. The pushrod becoming worn is possible, but seems unlikely to me. I would check that pickup tube.
  5. #4
    Nov 2010
    8
    yes,thats what it was,pickup tube partially plugged,couldnt draw enough fuel to run past idle
  6. #5
    David Biarritz is offline Cadillac Owners Member
    Automobile(s): 1961 Eldorado Biarritz 1983 Fleetwood Brougham coupe
    Apr 2013
    Melbourne Australia
    11
    WinkRe: 1961 cadillac fuel problem
    Just had the same problem with my 61 Cadillac Biarritz. Air in the filter bowl. I had enough fuel pressure from the pump, so this meant it was sucking up air with the fuel. I jacked the back of the car up and with a screw driver, tightened up the fuel line clamps on the hoses between the tank and the body fuel line pipes.
    Now the fuel filter bowl is full, I don't even get any bubbles going through it.
    Now the fuel filter bowl is full, I don't even get any bubbles going through it.http://www.cadillacforums.com/forums...ons/icon12.png
  7. #6
    Feb 2003
    california
    69
    6,611
    Assuming no leaks prior to the fuel pump, the air will purge itself. I think you have a problem with the lever and eccentric cam on the front of the camshaft. If I recall this cam is bolted to the camshaft. If loose, it would not move the fuel pump lever far enough. Some pumps required a Bakelite spacer between the pump and block to position the pumps lever on the cam. This is from memory so verify thru the internet.
  8. #7
    nyd
    nyd is offline Cadillac Owners Member
    Mar 2014
    1
    I am having the exact problem 1961 fleet 62 390 new carb and lines pumping fuel but filter runs dry and car quits
  9. Remove Advertisements
