Tire pressure on an old Caddy
Results 1 to 6 of 6
The Classic Cadillac Forum Discussion, Tire pressure on an old Caddy in Past Cadillac Vehicle Discussion; I have a '49 Caddy, series 62, 4 dr. sedan. It weighs about 4100 lbs. My owners' manual says that ...
    Raymond919 is offline Cadillac Owners Member
    Automobile(s): 1949 Cadillac Series 62
    Jul 2010
    71
    43
    I have a '49 Caddy, series 62, 4 dr. sedan. It weighs about 4100 lbs. My owners' manual says that the tires are designed to carry 24 lbs of pressure since the car is now equipped with 'extra-low-pressure tires mounted on 6" wheel rims'. The tires are supposedly designed to give 'maximum comfort and economy' due to their 'flexibility' to 'absorb rather than bounce over road irregularities'.
    Well, this is 2010 and I have no idea about these low pressure tires or if they've been dropped or whatever. My question is, what tire pressure should I use with the bias ply tires on the car now. Their size is 820 X 15, 4 plies.
    Can someone with tire experience tell me how many pounds to put in my tires? I've been carrying about 29 lbs.
    daniel58 is offline Cadillac Owners Fanatic
    Automobile(s): 58 Coupe Deville, 77 Coupe deville, 90 Deville
    Sep 2009
    183
    Re: Tire pressure on an old Caddy
    Do the tires have the max pressure marked on them, most do. I would start there, or a little below that max pressure.
    Jul 2010
    71
    43
    Hi Daniel,
    Thanks for your reply. On the sidewalls, my tires indicate a maximum pressure of 32 pounds. They are bias-ply. I currently have them at 28/29 pounds. On the road, my car tends to 'wander' and I need to constantly be correcting the steering with small adjustments. Could this be due to too high a pressure or is it just the nature of the car?
    Ray
    BlackHammer's Avatar
    BlackHammer is offline Cadillac Owners Member
    Automobile(s): CTS Coupe
    Aug 2010
    28
    6
    Sounds like the car wandering is due to wheel alignment and not tire pressure, unless the tire pressure changes greatly from one side of the car to the other.
    Jul 2010
    71
    43
    Many thanks for your comments. I have to have one part of the front suspension replaced later this month. Of course, the car will be aligned at that time. To answer your other comment, I've checked the pressure all around and all tire pressure is identical.
    I've appreciated all the comments and would still listen to any other thoughts on the topic.
    Sep 2009
    183
    I would tend to agree with Raymond, I had a 62 International truck that would wander and it was partially due to wear in the front end and alignment. All though the wander could be reduced by lowering the air pressure in the front tires, I wouldn't recommend that. Sounds like you are on the right track with the repairs and alignment. I'm not sure if your 49 has kingpins rather than balljoints but if it does they should be checked as well. New front wheel drive cars run 0 degrees toe in setting but the older stuff must have toe in to spec to minimize wander. You would want to be sure the alignment tech knows what he is doing and has the proper settings for this vintage car.
  9. Remove Advertisements
