1975 Eldorado HVAC blower motor speed
Results 1 to 8 of 8
The Classic Cadillac Forum Discussion, 1975 Eldorado HVAC blower motor speed in Past Cadillac Vehicle Discussion; My '75 Eldorado has developed an HVAC problem. Regardless of how I set the Climate Control settings, the fan only ...
    john campbell Guest
    My '75 Eldorado has developed an HVAC problem. Regardless of how I set the Climate Control settings, the fan only blows on the lowest speed. Any suggestions of what the problem might be or how to track it down would be greatly appreciated.
    John
    77CDV's Avatar
    77CDV is offline Cadillac Owners 10000+ Posts
    Automobile(s): 77 CDV, 06 DTS III, 69 FWB
    Mar 2006
    Newbury Park, CA
    45
    10,022
    Re: 1975 Eldorado HVAC blower motor speed
    According the the FSM, it's either a back-out terminal or disconnet at the control head, or an open in the blower circuit wiring.
    Feb 2003
    california
    69
    6,680
    If its like the sedans and coupes in those years, then the hi fan relay has failed or the wiring connector to it has melted over time causing a poor connection to the relay. Without a service manual, I would guess its like the sedans and possibly located to the left of the steering column underdash in a bank of relays on a common black plastic board. look for evidence of melted plastic just below one of the relays.
    pompste is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 SEDAN DEVILLE-4.9 & 1978 SEDAN DEVILLE-425
    Jan 2007
    1,673
    Quote Originally Posted by john campbell View Post
    John
    Hey John------did you ever get this problem solved? Check in and let us know. If you did get it solved---please post the fix.
    I`ve got the same exact problem on my '78 Deville----fan only blows on the lowest speed.
    john campbell Guest
    I'm afraid I've had several other vehicle repairs to take care of, and other things consuming my time unfortunately, so I haven't had a chance to get on this problem yet. But when I do, I'll definitely post the results.
    ace1233's Avatar
    ace1233 is offline Cadillac Owners Member
    Automobile(s): 1975 Cadillac Eldorado
    Aug 2013
    South Texas
    54
    3
    I seem to have to opposite problem....my fan only runs on HIGH....any thoughts
    CADforce69 is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac Sedan de Ville 1969, Dodge 3700GT '73, Audi A3 1.8T
    Oct 2010
    Madrid (Spain)
    49
    1,634
    Maybe the blower relay is bad so circuit is closed all time. This would be the easiest cause. If it´s not this, it would be necessary to check the power servo or the main control unit.
    ace1233's Avatar
    Aug 2013
    South Texas
    54
    3
    Thanks ....I will check it out and let you know. Appreciate this Forum....great to find a place to ask questions and get some real responses.
  11. Remove Advertisements
