Cadillac ATS 2016 has impressive performance and styling from the factory, but if you're one of those, for whom the factory equipment is never enough and want to get maximum from your Caddy, aFe Mach Force XP™ 304 SS Cat-Back Exhaust System would be a great find for you! This system is constructed of 2-1/2" mandrel-bent 304 stainless steel tubing for maximum performance, corrosion resistance and strength eliminating cracking. It performs up to 29% better than stock exhaust, giving you better exhaust flow, up to 11.5 horsepower and 9.5 lbs. x ft. of torque and improved performance.
This Mach Force exhaust system uses factory mounting locations providing stability and a hassle-free installation. It includes dual, high-flow mufflers and incorporates an X-Pipe to balance and evenly distribute exhaust pulses traveling through the exhaust system, minimizing exhaust drone, resulting in an awesome aggressive sound. The smooth curves and increased diameter of this exhaust system helps remove restriction and keeps exhaust gas flowing smoothly for increased horsepower and torque.
aFe® 49-34078-P - Mach Force XP™ 304 SS Cat-Back Exhaust System
aFe® 49-34078-B - Mach Force XP™ 304 SS Cat-Back Exhaust System
Afe Mach Force XP™ 304 SS Cat-Back Exhaust System is one of the upgrades for your Cadillac ATS, that you will never regret! Add it now and enjoy maximum performance and extreme mileage gains of your ride!
