Results 1 to 2 of 2
Thread: 1999 Eldorado taillight problems - Hello Cadillac !
    May 2013
    3
    I have an 99 eldorado i had it for seven years and now the only problem that i am having is that i dnt have any break lights when the other lights are on i have changed the break switch along with the the light switch all fuses are good as well as bulbs.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,854
    Re: hello cadillac my family
    This post has nothing to do with Site issues or registration. Please read the descriptive text in each forum title to find out what gets posted there.
    Moved to Seville/Eldorado.
    You might want to check the taillight wiring for chafing or breakage where it exits the left trunk hinge channel and also check the wiring harness ground at the left rear fenderwell body metal - under the carpet. The brake/outer taillights lights also each have their own wiring harness and I think the ground point is in the lower fenderwell quarter - down under the carpet.
    Anyone have a lighting schematic for a '99 Eldorado ??
  • You may not post replies
