Reverse lights - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
Like Tree2Likes
Cadillac XTS Forum Discussion, Reverse lights in Current Cadillac Vehicle Discussion; Originally Posted by 5.0 lsc ... http://www.superbrightleds.com/morei...se-tower/1127/ Thanks 5.0 lsc I got the the lights. they look good. Thank you!...
  1. #16
    r34220's Avatar
    r34220 is offline Cadillac Owners Fanatic
    Automobile(s): 2013 XTS Platinum
    Nov 2012
    115
    Re: Reverse lights
  2. #17
    sonny3621's Avatar
    sonny3621 is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 XTS Premium in Silver Coast Metallic
    Mar 2006
    Beautiful Glen Mills, PA
    512
    Re: Reverse lights
    Are the bulbs in that link for both the tag lights and reverse lights? Do they share the same bulb?
  3. #18
    5.0 lsc's Avatar
    5.0 lsc is offline Cadillac Owners Fanatic
    Aug 2010
    Philadelphia
    214
    Quote Originally Posted by sonny3621 View Post
    Same type of bulb but the tags dont have to be canbus proof.
  5. #19
    sonny3621's Avatar
    Mar 2006
    512
    Re: Reverse lights
    Which ones would you suggest for the tag lights?
  6. #20
    longslim is offline Cadillac Owners Fanatic
    Aug 2012
    So/Cal
    65
    118
    Re: Reverse lights
    Quote Originally Posted by 5.0 lsc View Post
    Is this a simple plug and go install?
  7. #21
    sonny3621's Avatar
    Mar 2006
    512
    Re: Reverse lights
    I spoke with a tech at the Superbrightled site and he said to order this for the reverse lights --->
    http://www.superbrightleds.com/morei...se-tower/1128/ and this for the tag lights ---> http://www.superbrightleds.com/morei...se-tower/1127/ and in natural white. He said both applications need to be CAN bus.
  8. #22
    sonny3621's Avatar
    Mar 2006
    512
    Re: Reverse lights
    I just spoke with a different tech at the Superbrightled site and he said that if you remove the bulbs from the tag lights and reverse lights and don't get an error code on your dash (which you don't on the XTS) then you shouldn't use the CAN bus LED's and he gave me several different options of non CAN bus LED's to use. So now I'm not sure which ones to get. I may order several of each type and see what works and return the others.
  9. #23
    5.0 lsc's Avatar
    Aug 2010
    Philadelphia
    214
    It won't hurt to get can bus for both. What was happening was when I installed standard LEDs in my reverse lights they, along with the door handles and some cue buttons, stayed on all night at like 25% brightness. As soon as I put can bus LEDs in my reverse lens the problem went away and everything was 100%. You might want to order the whole car, you have the trunk, glove box, center console, and the puddle lights on the bottom of each door.
  10. #24
    Zl700's Avatar
    Zl700 is offline Cadillac Owners Fanatic
    Automobile(s): 2014 XTS-Vsport
    Jun 2012
    Houston, TX
    54
    335
    You don't need can bus for tag lights with LED
    If you don't use can bus for backups, they will glow and drain your battery
    I tried it and confirmed on my 14, I then used xenons for my reverse
  11. #25
    sonny3621's Avatar
    Mar 2006
    512
    Re: Reverse lights
    What xenon bulbs are you using for your reverse lights?
    I was hesitant on buying CAN bus LED's for the tag lights as in the product description on the Superbrightleds site it says to not use CAN bus LED's in non CAN bus applications. You posted the LED's you are using for your reverse lights. Which ones are you using for your tag lights? Thanks.
  12. Remove Advertisements
