Low tire pressure
Results 1 to 6 of 6
Cadillac XTS Forum Discussion, Low tire pressure in Current Cadillac Vehicle Discussion; Why does my XTS seem to lose tire pressure often? Is the tires, rims or what....
    Lizbill's Avatar
    Lizbill is online now Cadillac Owners Fanatic
    Automobile(s): XT5Prem/Luxury White tri-coat
    Jun 2013
    South Carolina
    379
    Low tire pressure
    DG2's Avatar
    DG2
    DG2 is offline Cadillac Owners Connoisseur
    Jul 2004
    1,703
    Quote Originally Posted by Lizbill
    Do you live in the part of the country getting hit by this Arctic blast ??
    malatu's Avatar
    malatu is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS 3.6 AWD
    Dec 2005
    1,005
    Re: Low tire pressure
    I have a slow leak in in one of my tires/wheels. Took it to the tire store.... says no leak. So why does it loose a lb of pressure every week?
    I've found that you have to get them to check it the second time. The second time around they always seem to find the leak. I had this happen once before. Took it in the second time and they discovered it was corrosion on the rim. Depending where the tire/wheel's position (when parked), it would sometimes leak air, other times not. At least that's what I was told. They removed the tire and hand-sanded the lip of the rim smoothing it. It solved the problem. This particularity rim was on a 10 year old car.
    C&C's Avatar
    C&C
    C&C is online now Cadillac Owners Connoisseur
    Automobile(s): Cadillac XT5 (2017)
    Feb 2008
    Mount Pleasant, SC
    66
    1,976
    If all tires are responding alike then it is typically an air temperature condition (1 psi per ten degrees F* change; up/down). If one wheel is losing pressure then it can be a variety of things, i.e., puncture, air valve, porous wheel, poor mounting, etc.
    Lizbill's Avatar
    Jun 2013
    South Carolina
    379
    Quote Originally Posted by DG2 View Post
    Kinda, in the not so Sunny South
    dreiloft's Avatar
    dreiloft is offline Cadillac Owners Fanatic
    Automobile(s): 2014 XTS, 2012 Coupe traded, 2010 CTS 4 Dr traded
    Feb 2012
    Doral, Fl
    325
    When we drove to PA from Fl two weeks ago, I lost 6lbs of pressure per tire.
  9. Remove Advertisements
