xts easy exit
Results 1 to 7 of 7
Cadillac XTS Forum Discussion, xts easy exit in Current Cadillac Vehicle Discussion; I just got my 2013 xts and I set the easy exit up, however it doesn't work automatically. It will ...
    kennyxts's Avatar
    kennyxts is offline Cadillac Owners Fanatic
    Automobile(s): 2013 xts
    Dec 2013
    111
    xts easy exit
    I just got my 2013 xts and I set the easy exit up, however it doesn't work automatically. It will work when I hold the button down.
    Is there a way to make it work automatically?
    Cadjiek is offline Cadillac Owners Fanatic
    Automobile(s): 2015 xts Premium fwd 2009 CTS AWD
    Apr 2009
    472
    Re: xts easy exit
    make sure Easy Exit option is ON. In Settings got to Vehicle, Comfort and Convenience then Easy Exit and make sure On is checked.
    kennyxts's Avatar
    Dec 2013
    111
    Re: xts easy exit
    Thanks for the reply. I have it on the on position and it only works if I hold down the exit button. I want to know if it can be made to work without me holding the easy exit button down.
    Apr 2009
    472
    Re: xts easy exit
    Now I'm stumped. If the setting is set to on it should work when opening the door when getting out and go back to your preferred driving positions when starting the car.
    anybody else have an idea??
    nstar is offline Cadillac Owners Fanatic
    Automobile(s): 99 Eldo ETC 04 SRX V8 AWD 13 XTS
    Jan 2005
    202
    Re: xts easy exit
    Try this
    Automobile(s): 2013 XTS 2009 CTS AWDJoin DateApr 2009Posts354
    Re: Memory seat reprogram
    I just went out and programmed my other fob. I started the car and hit the lock symbol on the fob. I then set my steering and seat positions to my liking. I press "set" on the door panel and the driver number and that's it. I don't press both buttons at the same time as you described. That's it. I still think one of the problems is that you don't know which fob is being programmed. #1 or #2. They used to note the number on the fobs. I'm surprised the salesperson didn't help you with this when you picked up the car. Mine did. I ran into the problem after the memory seat update that was performed which for some reason switched the fob numbers.
    http://www.cadillacforums.com/forums...reprogram.html
    kennyxts's Avatar
    Dec 2013
    111
    Re: xts easy exit
    I use the same FOB as I did for my seats. I don't know if it's 1 or 2 but it seems to me that it should still work. I could see a problem if not using the same FOB, but I am using the same one.
    Jan 2005
    202
    Re: xts easy exit
    http://www.cadillacforums.com/forums...reprogram.html Read this thread completely
    • Quote Originally Posted by kennyxts View Post
  10. Remove Advertisements
