weird dash light on xts
Results 1 to 4 of 4
Cadillac XTS Forum Discussion, weird dash light on xts in Current Cadillac Vehicle Discussion; My xts has a light on dash the enhanced one is one I'm using to the right of the cruise ...
    rhmichaels is offline Cadillac Owners Member
    Nov 2013
    23
    My xts has a light on dash the enhanced one is one I'm using to the right of the cruise I have gotten an orange light looks like the cruise control lite but it has what appears to be an arrow around the right side... Only has been lit three times for just a second or two can find nothing in manual? Anyone know what it is For?
    Kenneybrock is offline Cadillac Owners Member
    47
    18
    Re: weird dash light on xts
    This is the speed limit warning light. When activated in the settings, this illuminates when the vehicles exceeds the posted speed limits.
    r34220's Avatar
    r34220 is offline Cadillac Owners Fanatic
    Automobile(s): 2013 XTS Platinum
    Nov 2012
    115
    Quote Originally Posted by Kenneybrock View Post
    Can you explain step by step on how to get to that setting?
    47
    18
    Note: The vehicle must be started to access this menu.
    This feature is NOT activated in the settings menu. Instead, it's accessible via the Vehicle Info settings (Similar to where you find the trip odometer, tire pressure levels, etc)
    In this submenu, you should see a "Speed Limit" option, and below the speed limit box, there is text that reads, "Press SEL to display in speedometer" If you press SEL, this activates a toggle and the text will now read, "Press SEL to turn off in speedometer".
    If left in the "On" position, the icon should appear when the vehicle exceeds the posted speed limit, if the vehicle is equipped with this option.
    FYI, this setting is located between the "Distance to Destination" setting and "Speed Warning". Also, for some reason this only seems to work for a few drive cycles, and has to be periodically turned back on.
  7. Remove Advertisements
