Air Conditioner compressor-when is it on ?
Results 1 to 6 of 6
Cadillac XTS Forum Discussion, Air Conditioner compressor-when is it on ? in Current Cadillac Vehicle Discussion; With climate control in auto mode, how can I tell when the compressor is on ? My Buick Enclave goes ...
    Sailerph is offline Cadillac Owners Member
    Aug 2013
    7
    My Buick Enclave goes on about 40 degrees, but a small light shows that. Thanks
    kipsts is offline Cadillac Owners Fanatic
    Automobile(s): 2013XTS Platinum, prior: 92,95,97,00,02,and 2005 STS
    Aug 2011
    Las Vegas
    352
    Re: Air Conditioner compressor-when is it on ?
    Quote Originally Posted by Sailerph View Post
    I am not sure I understand your question. If your interior temperature is staying where you want it, everything is working fine. If you lower the temp from where it is set and you feel colder air coming through the vents, your compressor is clearly working. What do you mean that your Enclave goes on about 40 degrees? C or F, interior or exterior? Also if your temperature in the cabin stays where you want it, why do you care?
    Aug 2013
    7
    The Buick Enclave in auto mode: The compressor won't come on until outside temp is about 40 degrees F or higher and a lite will then come on. Just curious, no big deal.Everything works fine
    Aug 2011
    Las Vegas
    352
    'No issues mon' just trying to understand to see if I could help There is no separate indicator light on the XTS for the compressor. Interesting re the 40 degrees. Used to be that you were advised to run your AC periodically during the winter to keep the seals lubed. I don't know if that is still true with today's compressors. I know that when I used to do that (before living in Vegas) you could turn on the AC and kick in the compressor even with outside temps near freezing.
    Cadjiek is offline Cadillac Owners Fanatic
    Automobile(s): 2015 xts Premium fwd 2009 CTS AWD
    Apr 2009
    468
    That's very true about the compressor with outside temps. That winter sun can warm an interior very
    quickly. The compressor comes on based on interior temps.
    Kenneybrock is offline Cadillac Owners Member
    47
    18
    Quote Originally Posted by Cadjiek
    Also on modern cars, the AC compressor comes on when operating the front defroster in the winter.
    If you press the snowflake on CUE, you will find an option for turning the AC compressor on or off.
  9. Remove Advertisements
