seat memory problem . 2014 XTS
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
Like Tree2Likes
Cadillac XTS Forum Discussion, seat memory problem . 2014 XTS in Current Cadillac Vehicle Discussion; ...
    winton is offline Cadillac Owners Member
    Automobile(s): xts
    Aug 2013
    72
    I picked up a new 2014 XTS yesterday and am having trouble with the seat memory
    1. First of all, the manual says to “press and hold BOTH set and #1 at the same time” that obviously is wrong. If I press and release set and then press 1 I get one beep
    2. BUT there seems to be some OVERRIDING SETTING . is there a way to delete all seat memory settings and start over???
    3. The driving seat memory seems to work BUT DOESN’T auto go there when I start the car???
    4. I programmed the “exit” memory but it doesn’t go where I set it. INSTEAD it goes to some crazy setting with the seat way back AND TITLED FORWARD
    a. Yes, I have “easy exit” set to “on” on the panel
    b. And I’ve tried both keys. Same problem
    garrykolb is offline Cadillac Owners Member
    Automobile(s): 2013 XTS Platinum
    Aug 2013
    Holt, MI
    18
    Read the manual again. I had to as well. Move the seat to your position and hit set & 1 simultaneously. It will beep. Move to your exit position. Hit set & exit simultaneously. It will beep. To fully move to a memory position, hold the proper button down until the seat, wheel, etc, are done moving. When the car engages the memory position or exit position, it will move fully.
    Also, when opening your door to exit the car, be sure your hand does not hit a button. If you do, it stops the easy exit. That frustrated me until I figured it out.
    RockvilleXTS's Avatar
    RockvilleXTS is offline Cadillac Owners Fanatic
    Automobile(s): XTS Platinum
    Dec 2012
    Rockville, MD
    151
    Re: seat memory problem . 2014 XTS
    One other thing I've found. If you put the car in Park, you can hit the seat button(s) once, and they go to their full set positions. If you are in Drive, you have to hold the button down continuously for the seats/steering wheel to move fully to their preset position. At least, this is how it works on my car. Also, as garrykolb mentions, be careful NOT to hit the seat buttons when you open the door. That stops the movement and prevents achieving the full preset position.
    garrykolb likes this.
    ipncjh1's Avatar
    ipncjh1 is offline Cadillac Owners Member
    Automobile(s): 2014 XTS Vsport Platnium
    Jun 2003
    Lucas Texas USA
    55
    Does anyone think it is odd that "To fully move to a memory position, hold the proper button down until the seat, wheel, etc, are done moving.". I have had dozens of GM cars with memory recall and you only push the button once, not have to hold it down.
    gator2305 is offline Cadillac Owners Member
    Jan 2014
    19
    The DTS that I traded for the XTS and other GM vehicles with the memory seat option I have owned all would have the seats and mirrors set to the driver position preset to the remote fob if the remote was used to unlock the vehicle on approaching.
    I was surprised when I got the XTS and found the memory seats did not function like in the DTS. I discussed this with the Service personnel and they advised they had heard women had complained and changes were made. They advised most women regardless of size and stature drive with the seat as far forward as it will go. This creates problems in getting in and out of the vehicle.
    Lizbill likes this.
    r34220's Avatar
    r34220 is offline Cadillac Owners Fanatic
    Nov 2012
    115
    Quote Originally Posted by ipncjh1 View Post
    I have a 2013, If in park it works with a single press. If in drive it has to be held down to fully move.
    Tanker is offline Cadillac Owners Member
    Automobile(s): None
    Aug 2014
    None
    1
    I've attempted many times to push both Set and 1 at the same time and hold them both for 15-20 seconds but no beep. Is there something else that needs to be done? I've attempted it in Park, in Neutral, in Drive, door open, door closed, engine running, engine off, etc. but no luck.
    __________________________________________________ _______________
    Good evening, Your CF account is registered. Please use the Profile tab to update your profile to show correct information and time zone - or do you really live in London - GMT ?
    Set your preferences, press 1, beep, then press Set. Same for the other - #2.
    sonny3621's Avatar
    sonny3621 is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 XTS Premium in Silver Coast Metallic
    Mar 2006
    Beautiful Glen Mills, PA
    502
    Contrary to what was posted earlier you don't push them at the same time. Push Set first, release, and the immediately push either 1 or 2 and you will hear the beep.
    330GT is offline Cadillac Owners Member
    Automobile(s): 1999 STS,2013 XTS-P, 2014 XTS-P
    Oct 2012
    Southern California
    54
    Quote Originally Posted by sonny3621 View Post
    I guess everyone has his own version of the procedure because in the O/M for my 2014 XTS, page 3-7, Storing Memory Positions, # 2 states: Press and hold SET and "1" at the same time until a beep sounds. It does work as intended now on my XTS because the seat memory module was replaced when the car had some 70 miles on the clock.
    By-the-way this was the same procedure for my 2013 XTS.
    Is the O/M wrong? Was this updated for the 13 and 14 O/M?
    sonny3621's Avatar
    Mar 2006
    502
    Mine only beeps when you push the Set, release it and then push 1 or 2. If I push Set and 1 or 2 at the same time it won't beep.
    WayneC is offline Cadillac Owners Member
    Jan 2015
    Mt. Sterling, KY
    3
    Same here. My 2013 XTS Memory Seat function works the same. (Push Set, release, push 1 or 2 to get the beep).
    5.0 lsc's Avatar
    5.0 lsc is offline Cadillac Owners Fanatic
    Aug 2010
    Philadelphia
    214
    I have a 13 and im pretty sure there was an addendum they gave me for owners manual for the memory seat section because it was wrong. Mine works fine. You have to press and hold either 1 or 2 to get to the setting. The dts you would just tap the button and it would do it. My easy exit seat works as soon as the door is opened. When i get back in the car it goes back to memory seat position once the vehicle is started. The dts was also different in this aspect because the easy exit option would activate as soon as the vehicle was shut off.
    Also keep in mind that there are 4 memory settings in total 2 for each key fob.
    Goumba64's Avatar
    Goumba64 is offline Cadillac Owners Member
    Automobile(s): 2014 Cadillac XTS Luxury Plus, White Diamond
    Nov 2013
    Texas
    29
    Mine works just fine and as well as my other two Cads. Set it all up in the beginning and work as supposed to. Exits the way I want. Car is back to my setting when I get back in. I press and hold both like some have said if I want to change the memory position.
  16. #14
    31moppie is offline Cadillac Owners Member
    Automobile(s): 76 Eldorado, 2013 XTS Luxury
    Sep 2011
    56
    7
    Just purchased a used 2013 XTS for my wife as primary driver so she is set up as driver #1 and myself as #2. I could not for the life of me get the remote to recall memory #2 position. #1 position seemed to be to only one that the seat would go to which was really frustrating as this was one of the features that we liked about the XTS. I quickly realized that the owners manual is way out in left field. Just for chuckles, I read the 2014 manual and it is better but still not right. By 2015, Cadillac writers must have figured it out because it is correct. Still didn't solve my problem though. Had to take the car to dealer for other work and asked them to look at it. Turns out that one of the remotes is numbered as #3 and that the previous owner must have replaced one or bought an extra one. They reprogrammed them and it works perfectly now. The added bonus is that they did it for no charge. Hopefully this may help someone else with the same problem. Love the car btw
  17. #15
    Gavinallan1 is offline Cadillac Owners Member
    Automobile(s): XTS4 Luxury
    Nov 2014
    96
    Cadillac needs to borrow a Honda Pilot Touring Edition to see how memory seats should work. The Honda is so simple, intuitive, and consistent. The Cadillac is a nightmare...
  18. Remove Advertisements
